Go to Post Your cat-bell skills are most impressive. - Andy Baker [more]
Unread 22-07-2006, 22:03
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
15 min. epoxy vs. Elmer's ultimate glue
Hi,
I need to repair a model rocket fin that has been cracked at the intersection of the fin and body tube.
My friend told me to use 15 minute epoxy to repair it, but I have heard that Elmer's Ultimate glue is the stronger glue (beating Gorilla Glue by 40% (according to an ad)). What do you guys think? Which one is stronger?
Thanks
Unread 22-07-2006, 22:21
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Re: 15 min. epoxy vs. Elmer's ultimate glue
I use Epoxy @ my work (mechanic) and I have not had a problem with it.
Never used the Elmer's Ultimate Glue though. I'd worry about the high temps - and agian, I love my epoxy.
I'd go for the epoxy.
That rug really tied the room together...
Unread 23-07-2006, 02:31
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Two-part epoxies by far are a lot stronger, and I will also recommend you use the 15 minute epoxy. One thing that I have (unfortunately) learned from experience is that 15 minutes is not the curing time, but the setting time. The setting time is the amount of time for the epoxy to become rigid, but not reach full strength. The curing time is the time it takes for the epoxy chemical reaction to end (true epoxies are chemical reactions) and reach full strength, typically 24 hours.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 23-07-2006, 02:46
What's the fin made out of? Choosing the right adhesive has a lot more to do with matching the proper materials than in determing some absolute level of "good."
If the fins are HDPE, for example, neither of the adhesives you name would be a good choice.
Unread 23-07-2006, 08:35
aksimhal's Avatar
AKA: Anish
The fins are made from plywood and the body tube is cardboard.
Thanks
Unread 23-07-2006, 08:43
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
According to the link you posted, the fins are precise cut plywood. I'd go with the epoxy. To reinforce the joint, you can embed some fiberglass window screen material into the epoxy on both sides of the fin similar to fiberglassing something.
Mix your epoxy and apply to the both sides of the break. Place the fin back on and then apply more epoxy to each side of the fin and body tube and press the window screen into the epoxy across the break so that its tight to the fin and body tube and the excess epoxy is forced out through the screen. Then use a piece of scrap 0.020 plastic sheet or index card as a squeegee to spread the epoxy out in a thin layer over the screen and remove extra epoxy.
Next, use masking tape or your favorite method of holding the fin in position until the epoxy cures (24 hours), but check it a few times before the epoxy sets to make sure the fin is still straight. After curing, trim any screen overhanging the fin, sand lightly and your repair should be good for launch. If you want really strong screen, Home Depot sells screening which is labeled (I think) "Dog Proof". It has extra fiberglass strands or Kevlar strands embedded in the product.
Also, if this fin broke off during a landing impact, you might want to consider applying a fillet of epoxy to each fin where it joins to the body tube to strengthen all the joints.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 23-07-2006, 12:28
Arthur's advice is excellent. If you can repair the fin off the rocket, you might lay the fin on a piece of polyethelene plastic (the plastic sheets sold in rolls in home centers are mostly poly) create your repair with epoxy and fiberglass stiffener, squeegee out the excess epoxy, and the cover it with another layer of poly. Place a large flat weight on top of this sandwich and you will end up with a smooth, no-sanding-required surface.
Alternately, you can replace the poly with release fabric, which would "suck up" the excess epoxy in your laminate. Since you probably don't have any release fabric, you can just forget this part.
Good luck.
Unread 24-07-2006, 18:29
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Good luck.
What kind of release fabrics are you talking about, because from what I have read I thought it was only used when it cures in a vacuum, or vacuum bag. Kinda like when they make huge carbon fiber parts.
Unread 24-07-2006, 18:46
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
At first I thought release fabric was like glass mat or kyntex. However, I was wrong. I used this to help explain what release fabric is.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Epoxy, glue, loctite gear to shaft. Any chance of working? sanddrag Technical Discussion 11 15-01-2007 05:40
The Ultimate Showdown of Ultimate FIRSTiny Billfred Chit-Chat 4 12-04-2006 22:43
Min/Max Problems? AndyKK2 Programming 2 16-02-2003 21:12
is it really just 2 min? archiver 2001 1 23-06-2002 23:05
FYI: 15-30 min downtime Brandon Martus Announcements 0 01-03-2002 22:57
