Go to Post I disagree with the "letting them fail" philosophy. - wireties [more]
Unread 25-07-2006, 19:27
Dick Linn's Avatar
no team (Synergy)
Re: Cutting Lexan
Sorry, I was thinking of acrylic and the directions I read recently on one of those cutters. Polycarb is indeed tougher. That I would not hesitate to cut with most any sharp sawblade, just don't feed it too fast or hard. And it doesn't like to be fed through a very fine jigsaw...it tends to heat up and weld itself back together. Very annoying!
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 18-08-2006, 14:53
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Cutting Lexan
When is comes to lexan the standard blade thatc omes with the table saw is perfectly fine to use however make sure you compensate for the 1/8th inch cutting path is creates. For acrylic i have found that a diamond blade does a pretty good job, however just to be safe you have to put tape on the acrylic while you are cutting it, 3M painters tape is teh best for this. Again when cuttign with the diamond blae make sure your compensate 1/8th of an inch for the cuttign path
Championship - Delphi "Driving Tomorrows Technology"
Unread 22-09-2006, 00:30
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Cutting Lexan
I just ran across this Acrylic Sheet Fabrication Manual that has a lot of good info on cutting and machining Plexiglas/Acrylic.
Unread 24-09-2006, 22:51
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Re: Cutting Lexan
I know that a lot of teams may not have this luxury, but just about all our lexan was laser-cut.
Unread 25-09-2006, 03:37
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Cutting Lexan
The size of the pieces you are cutting is limited by the size of the bed. If you were cutting a piece over three feet long you would have trouble. But I must agree, for small pieces or small parts you can't beat the 0.03" wide cutting path. Lucky guys!!!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Cutting Lexan dagger Technical Discussion 14 15-02-2006 15:20
Working with Lexan Phil Paspalas Technical Discussion 41 09-02-2006 16:14
pic: Lexan + Heatgun = CD47-Bot Robot Showcase 4 21-02-2004 00:19
Lexan, the wonder material archiver 2001 12 24-06-2002 02:10
lexan bender JamesJones Technical Discussion 9 12-05-2002 18:50
