Go to Post I have a feeling that we're about to deprive the world of Poof balls for a while. - DCA Fan [more]
Unread 25-07-2006, 20:36
CraigHickman
Posts: n/a
Re: pic: 114 2 speed Coaxial Crab Drive
Originally Posted by Tom Bottiglieri
It looks like the "put the power to the wheels" drive transmission is modular, in the sense that it can fit on any of the 4 sides of the chassis
This is the precise reason behind designing the frame and gearbox as it is. If need be, we could change the bot into a 4 wheel tank drive, with minimal work required. As well as this, once the game challenge comes around, this design is very modular, to allow the best possible game manipulator to be added with as much space as needed to the frame.
[edit]
As for experience doing a Crab, this is building off of our Triple Play Crab drive, which worked quite well. This design allows for easier programming (that goes along with a fun new control and OI scheme), easier machinability, and a lighter weight system. Did I mention it has a 2 speed?
Unread 25-07-2006, 21:42
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Love this idea, I have some sick and twisted designs in my head that look like this. One question I have for you, ever think of making the four wheels orient in a square rather than a rectangle? That way you'd have a zero degree turning radius, and would be able to turn faster with more precision. That gearbox idea was similar to what I have thunked up, the only difference is you've got yours to cad allready. But I DO LOVE THE DESIGN!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 26-07-2006, 01:09
run the trap!!!
Team Role: Human Player
How are you going to tension the chain off of the globe. Are you planing on using one or two chains. I'd like to see a picture.
Keep up the good work.
Keep posting.
-Philip J. Fry
Unread 26-07-2006, 01:19
CraigHickman
Posts: n/a
For the tensioning of the steering chain (the one that will be attached to the globe) I have a set idea: Two 1/4" plates, with two delrin rollers, running the chain to the steering sprocket. The two rollers will form a triangle with the globe sprocket, making a nice tensioning system, and giving the sprocket nice wrap.
Will post picture upon CAD completion of that system
Unread 27-07-2006, 01:46
run the trap!!!
This is exactly what I have implemented into my own swerve design. I have had some bad experiences with Delrin chain tensioners, so I am wary of this approach. I may decide to use idler sprockets instead.
Have you considered timing belts? What are the pros/cons of using them.
(yeah, I'm too lazy to make a real chain in inventor (black-thing = chain))
-Philip J. Fry
Unread 27-07-2006, 01:49
CraigHickman
Posts: n/a
I've used timing belts before... And had bad experiences with them. When doing a rapid change in direction, The belt tends to skip... aka bad stuff, bad noise, bad wear.
So chain seems like the better option... for this application, that is.
Unread 27-07-2006, 10:08
in between teams
AKA: Luke Van Oort
I can't recommend idler sprockets enough, they're easy to work with, reduce your efficiency losses, and aren't too heavy. Here is a picture of our implementation of them on a u-bolt, this design can easily be mounted on some aluminum angle and can be used sideways (although the chain might be a bit more likely to fall off, but some sort of spacer on the u-bolt could solve that problem, if it occurs) a simple nut can adjust tension, or they can even be spring loaded, as I suggested here .
Team 1219: 2009 - Mentor
pic: 114 Coaxial Final CAD CraigHickman Extra Discussion 3 01-07-2006 22:45
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Coaxial crab CD47-Bot Extra Discussion 9 08-02-2004 20:08
pic: Coaxial Lego doubble-wishbone crab CD47-Bot Robot Showcase 7 10-12-2003 12:10
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
