Re: pic: 114 2 speed Coaxial Crab Drive
This is exactly what I have implemented into my own swerve design. I have had some bad experiences with Delrin chain tensioners, so I am wary of this approach. I may decide to use idler sprockets instead.
Have you considered timing belts? What are the pros/cons of using them. (yeah, I'm too lazy to make a real chain in inventor (black-thing = chain)) |
I've used timing belts before... And had bad experiences with them. When doing a rapid change in direction, The belt tends to skip... aka bad stuff, bad noise, bad wear.
So chain seems like the better option... for this application, that is. |
I can't recommend idler sprockets enough, they're easy to work with, reduce your efficiency losses, and aren't too heavy. Here is a picture of our implementation of them on a u-bolt, this design can easily be mounted on some aluminum angle and can be used sideways (although the chain might be a bit more likely to fall off, but some sort of spacer on the u-bolt could solve that problem, if it occurs) a simple nut can adjust tension, or they can even be spring loaded, as I suggested here .
| pic: 114 Coaxial Final CAD | CraigHickman | Extra Discussion | 3 | 01-07-2006 22:45 |
| pic: Coaxial Crab drive | CraigHickman | Technical Discussion | 1 | 21-06-2006 16:03 |
| pic: Coaxial crab | CD47-Bot | Extra Discussion | 9 | 08-02-2004 20:08 |
| pic: Coaxial Lego doubble-wishbone crab | CD47-Bot | Robot Showcase | 7 | 10-12-2003 12:10 |
| pic: Coaxial Lego Crab drive | CD47-Bot | Robot Showcase | 11 | 04-11-2003 14:45 |
