Go to Post And then have FIRST throw a copy of the Atkins diet book in with each kit... - dlavery [more]
Unread 27-07-2006, 22:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Timing Belt Drive System
I haven't touched timing belt since 2002 and had limited success at that, but I can see its appeal. The single largest issue I had to overcome in both 2001 and 2002 was preventing the belt from walking off the pulleys.
Out of curiousity, since it appears as if you're striving simply to replace roller chain with timing belt, have you considered taking things one step further and replacing the wheels with timing pulleys? It aggravates the problem mentioned above, but there are self-aligning belts and things that I've never been able to play with that may alleviate some of that concern. If there's a simple way of keeping your belts on, it'd seem a no-brainer to save even more weight by riding directly on your pulleys rather than attaching them to a wheel.
--Madison--
...down at the Ozdust!
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
Timing Belt and Pulley Joe_Widen Technical Discussion 4 16-01-2006 13:41
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Timing Belt Recommendations? Eric Reed Technical Discussion 1 10-01-2002 00:25
