#13
Re: Steve Jones and his physics analysis of 9/11...
ok I watched part of it and read the summary in the post above. A couple of points:
1. The professor shows bldg 7 falling, and buildings that were intentionally demolished falling, and says something to the effect of "it looks the same" what does that mean? If someone is poisoned and someone has a brain aneurysm, Im willing to bet they look pretty much the same as they fall to the floor. The fact that they fall the same way doesn't mean the cause of failure is the same. Logical fallacy. 2. The professor makes a big point that many sky scrapers have caught fire and burned, and none of them ever collapsed until 9/11. Ok, but how many of those other buildings had a fully fueled jetliner jammed into the center of their frame at the time? Most buildings are not constructed with materials anything like ten thousand gallons of jet fuel. There was nothing in those other buildings that would combine with the updraft rush of air to burn like a kerosene fueled blow torch. 3. Metal was seen pouring out of one tower? There was a jet aircraft in there, made mostly of aluminum! Aluminum does burn if you get it hot enough, and it would certainly melt in this type of a fire. 4. The fact that an engineer was fired from UL, after his computer models could not replicate the fall of the towers, what are we to conclude? That he was fired to cover up his discovery, or that he had no idea what he was doing, or how to model something this complex with the computer SW he was using? Could he have been fired for being incompetent? 5. The WTC area was cleaned up quickly because the cause of the fires and collapse was already known - it was captured on cameras, the second impact was seen live by millions of people, there was no mystery. If someone is shot multiple times during a robbery, with 10 million eye witnesses, and dies on the spot, Im pretty sure you dont have a bunch of doctors running tests, thinking "maybe his wife poisioned him? maybe he was hit by lightning?" 6. Why did bulding 7 fall? Because the towers that fell were right across the street, and tons of debris fell onto bldg 7, and the shock of the towers hitting the bedrock was like a localized earth quake. Again, nothing like this has happened before because nothing like this has ever happened before. There is no historical basis to look back on for similar events. If this professor had been part of the investigation team, had access to the site, access to the materials, and then decided something else was going on, then I would give him more credibility. But to look at videos, and eyewitness account from people who didnt understand what they were seeing, and who were in shock at the time, and base his conclusions on that data alone, that is not science. That is armchair speculation. Quote:
The towers were not punctured like a pencil through a window screen. We all saw the plane fly into the second tower. The plane sliced the entire side of the tower open from wing tip to wing tip, destroying the load bearing structure of the entire one side and corner of the building. I think this point alone demonstrates the poor science used by this professor. He could see with his own eyes that the entire side of the building was slashed open, but then presents the quoted statements about pencils and window screens. As this point you gotta ask yourself "what is this person really up to? What are his motives? Last edited by KenWittlief : 29-07-2006 at 11:04. |
| White Paper Discuss: Physics Analysis of a Ball Launcher | coastertux | Extra Discussion | 0 | 01-02-2006 17:58 |
| White Paper Discuss: Analysis of Ball Drag from Fundamental Physics | coastertux | Extra Discussion | 0 | 01-02-2006 16:49 |
| Who Drinks Jones Soda? | Ryan Dognaux | Chit-Chat | 9 | 25-08-2005 10:24 |
| pic: Steve W and Karthik | CD47-Bot | Extra Discussion | 4 | 08-05-2004 23:52 |
