Go to Post it should not matter the gender of a person but rather their ability. - vivek16 [more]
Unread 30-07-2006, 17:21
hello1990ab hello1990ab is offline
hello1990ab is an unknown quantity at this point
Sound Sensor
Hey it's been a while since I've posted here...
I've been given the task of finding a sensor from digikey that can react to a piezo buzzer (3khz to 4khz) that works with the current FRC gear.
I see they have a lot of microphones but I'm not sure how to sort them all out.
Thanks
Unread 31-07-2006, 07:42
Re: Sound Sensor
You need to be a little more specific in your question. What is the use for this device? What is the environment in which it will be used? etc...
Unread 31-07-2006, 09:37
Re: Sound Sensor
you will need more than a microphone (the robot controller does not have any inputs that would accept a microphone signal).
You would need to filter the audio signal, and convert it to something like a varying DC level signal, proportional to the level of the 3 or 4kHz sound.
How sensitive it needs to be, what other audio sounds will be present, the type of output (analog or digital....) would all be defined by your intended application, as Al inidicated.
What is the problem / requirement that this sensor is intended to solve?
3DS Max Sound GregTheGreat 3D Animation and Competition 5 28-01-2003 09:14
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
sound? kyo11103 3D Animation and Competition 0 17-01-2003 17:57
Sound Systems Andrew Rudolph Chit-Chat 25 09-11-2002 00:05
Robot Sound archiver 2001 0 24-06-2002 00:06
