Go to Post theres nothing more macho than something made entirely out of diamond plate. - Dan9874123 [more]
Unread 01-08-2006, 00:07
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
pic: Not the end of the Rainbow, but ....
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 01-08-2006, 00:08
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: pic: Not the end of the Rainbow, but ....
Now that is scary...and to think only a few milliamps can harm a person just see what can do to solid asphalt
MechWarriors 573
Unread 01-08-2006, 00:15
is that concrete or asphalt?
and what is the puddle of metal? melted wire? it looks like aluminum?
Unread 01-08-2006, 01:16
Elgin Clock's Avatar
FRC #0237 (Black Magic)
<Dr. Evil Voice> MAG-MA. </Dr. Evil Voice>
That's pretty impressive/scary Art. When did this happen?? I know we have gotten a ton of storms this past month or so in the area, so I'm not surprised something like that would happen.
It does look really cool though.
Although, I'm used to seeing roads closed lately, but not from being charred, but rather being washed out.
Unread 01-08-2006, 07:29
Amazing what a little 7920 volts can do. I suspect it found it's way to ground through water in the cracks in the driveway? A lot of the molten mass is drive material and what lies underneath with a little wire through in for color? Great picture, Art! Took a while for the fuse to trip I bet. Is there any other localized damage from the wire dancing around?
Unread 01-08-2006, 21:53
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
This was the lightning storm that rolled through on 7/28/06. The driveway was asphalt, but I have seen similar damage to concrete as well. What looks like metal in this mess is actually more like a crude glass called a fulgurite. The line conductor an aluminum alloy known in the trade as AAAC (aluminum alloy - aluminum core) with such a low melting point I'm pretty sure most of the conductor vaporized. The fulgurite is glass formed as the silicas in the underlying soils melt in the intense heat, the bubbles are cooled glass that was forced to the surface probably by escaping gases.
This particular line was protected by a 65 ampere k-speed fuse. K speeds are the fastest melt time fuses available. Unfortunately, this was a high impedance fault and it took several minutes for the fuse to clear this arcing fault. I'd hate to guess at the initial temperatures (3,000-4,000F?), it looked like molten glass or lava (cherry red). The local fire department emptied 300 gallons of water on the asphalt after power was cut, and all they accomplished was to make a lot of steam. I revisited the site 6 hours after the fault, as the crews were making final repairs and the asphalt 3-4 feet from this burn was still soft to walk on (probably 150F)
Other than the downed line and loss of power, the homes in the area suffered no damage. The damage was localized in this case. Wires down like this don't tend to "dance" around, they just lay there and burn like a giant arc welder.
What's even scarier is this was the smaller of two lightning strikes. The larger strike about one quarter mile from this site cut a major three phase circuit down, and left a flaming 2 foot diameter, 4 inch deep fulgurite crater in the middle of a major asphalt road. Unfortunately, I didn't get to photograph that strike. The public works crew had dug up the road and patched it before I got there.
Unread 02-08-2006, 07:48
I forget you are in a different part of the country so ground conditions are different. Here in Illinois, I have witnessed down lines that dance as ground water repeatedly seeps close enough for arc over and the resulting steam burst throws the end of the line around. Not the kind of arcing people see on TV or the movies but interesting none the less. These are the kind of things that elelctrical workers are exposed to all the time that the general public knows nothing about. Risky business!
Was the line hit by lightning or just downed through some other storm related event? A few years ago, I was watching out my back door during a lighting storm when a 113kV line was struck a few miles away. An arc over occured in a yard behind my where the service line drooped low. Arcwas about 16 ft. to ground from the low spot on the line. I am very near the end of the distro for my neighborhood, only one transformer after my house before the end of the line. Everything between my house and the intial strike was tripped. A lot of fuses were replaced that night.
Unread 02-08-2006, 21:04
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
Both events I described were direct hits to the distribution system. There were lots of tall trees in the vicinity but I couldn't find any evidence of the strikes hitting the trees. One strike was a direct hit on the pole itself. The pole top was split with a 3" exit hole about a foot down from the pole top bracket which then discharged into the lower arm brackets.
Unread 02-08-2006, 21:38
Personally I like huge thunderstorms. I assume everyone allready knows this: sound travels at approximately 1000 feet per second. When you see lightning and start counting off the seconds till you hear the thunder, you can measure how far away the lightning bolt hit the ground.
1 second is about one city block away. Half a second is 500 feet. When you get one of those you know something right in your neighborhood got hit!
If you see the direction of the lightning you might be able to go out after the storm and find the spot where it hit. Sometimes its easy to find, things like a tree with half the limbs and bark blown off one side!
Unread 02-08-2006, 21:53
CraigHickman
Posts: n/a
Man... I'm missing out on fun storms like that here in Cali. All I get is the ground shaking under my feet... Which gives you quite a sense for the scale of the earth, feeling what is just a tiny movement of pieces of the crust....
Unread 02-08-2006, 22:11
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
I'd rather have nasty thunderstorms and tornados than earthquakes anyday. I've seen about 5 or so tornados actually form in my life. One came down in the cornfield behind my house and went away from my house thankfully.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 02-08-2006, 23:23
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
I always think I like huge thunderstorms, but recently we have had the kind that scare the bejeebers out of me! Today I saw twin lightning bolts come down, they had to be a city block apart, as straight as straight could be and on either sode of the road I was traveling on. Makes you go WOW
I'm glad I wasn't at the end of them! And I certainly wasn't going to go look for any rainbows that they left behind!
Oh no, they are starting up again, about 3 seconds from flash to sound... no matter what the calculation is, I'd better get off my computer, even with the surge protector, we've lost the router before!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 02-08-2006, 23:46
Penfield - I was just going to say, speaking of Tstorms! We got one right now here in Fairport, NY
We have made some significant improvements over the years. All I have to do is reach over and pull the charger plug on my laptop, and Im running on a 'free UPS for 3 hours', completely isolated from the grid.
No chance of getting zapped through my cellphone either!
Unread 02-08-2006, 10:10
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
That was a nasty series of storms last Friday. I was surrounded by lightning on all four sides as I drove home from work (but no rain on the whole drive home until I got to my street). There was a lot of cloud-to-ground as well as cloud-to-cloud lightning. I have to drive under some high tension wires twice in my short trip home and both times I was praying that lightning would not choose to hit those as I passed underneath.
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 02-08-2006, 12:03
Nica F.'s Avatar
Nica F. Nica F. is offline
Mechanical Design Engineer
AKA: That silly panda girl from back in the day.
Nica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond repute
that is pretty scary. was there a lot of that around?
i havent been in a major thunderstorm in my life.
Product Designer, Mechanical Engineer
Purdue Aeronautical and Astronautical Engineer Graduate - Boiler up!
Team 22 Double Deuce / Team 4 Element Alumni / Former 1646 Precision Guessworks Mentor
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
pic: S.P.A.M's bot in the end tiffany34990 Extra Discussion 6 26-04-2005 13:18
pic: The end of nationals...everyone left at the same time CD47-Bot Extra Discussion 15 21-11-2004 18:50
She'll cheer for the Nimrods, but not for FIRST? Nick Seidl Chit-Chat 3 26-03-2004 15:03
pic: Lexan: Bulletproof, but not robotproof CD47-Bot Extra Discussion 6 21-03-2004 23:23
