Go to Post My nagging fear is that I'm a programming dinosaur, stuck in a procedural tar pit and doomed to extinction as the dataflow mammals take over. - Alan Anderson [more]
Unread 05-08-2006, 13:21
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: pint sized chaos v2
Originally Posted by Koko Ed
What weight class is it going to be?
it is in the feather wieght class (30 lbs)
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 05-08-2006, 13:45
CraigHickman
Posts: n/a
This looks cool... any chance of seeing the CAD models, so I can draw some influence off of how your design works?
By the way, what made you choose a belt to run your blade instead of chain? (I ask because I know nothing about the field of battlebots)
Unread 05-08-2006, 14:49
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
I like it, battle bots allows you to do a lot of things that many of us wish we could do in FIRST but unfortunately, never get the chance to.
I'm guessing there are no chains because they are more likely to snap in this situation, the belts hopefully would just slip. Would it be a possibility if the weight allows to just go with straight spur gears to get your reduction down, that way you'll keep your efficiency up a little more than with the belts?
How wide are your wheels? They are your first line of defence against the many plough type bots in competition, so wide wheels are always great (i'm sure greg knows that)
Also do you have a brake in the transmission on that?
Looks great, I love the slotted grille on the side that doubles as a way to lighten the machine. That would look really nice if you made it shinny for competition.
Unread 05-08-2006, 14:58
I am using belts strictly because of weight. I would love to use gears but unfortunately i really don't have the space and weight for them.
The wheels are 1.25 wide colsons.
There are no breaks on the transmissions, but I figure I won't need them because of the wedges and the fact I can move almost 10 mph.
In the long run I would love to polish then anodize the whole thing (something I have been wanting to try for a while). but since i have a very limited amount of time to actually build this bot I am going to be lucky to get it done.
Unread 05-08-2006, 22:54
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Another advantage of the belts is that if the blade is stopped through either being damaged or having a bot wedged in/stuck on it, the belt will slip, which should keep the motors from stalling and save a good bit of money over time.
Team 675-Alumni
Near Chaos Robotics
Unread 06-08-2006, 16:27
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
*sniff* It looks so pretty all assembled *sniff*
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 04-06-2007, 00:24
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
its a cute little robot, but arent the super heavy weights where its at? no way you can put a hpa system in that and get it to throw 340 lbs 10 feet up.
also im curious as to why a blade would be mounted on top of the robot?, to me it just seems harder, because you have to get the other guy on top before you do damage.
by the way, very clean and good looking cad.
Unread 04-06-2007, 06:41
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
The Super Heavies are super in most ways, meaning super expensive as well, thus being why there are not many built. There is also less of them competing than the Featherweight class this is being built for. For RoboGames '07 there are 29 Featherweights registered while there are only 7 Super Heavies (http://buildersdb.com/view_bots.asp?eventid=196).
The wedge fed design is meant to feed the other robot into the blade, the blade will hit the other robot (hopefully) from underneath and will send it skyward, of course the disadvantage is if the opponent has a lower wedge then you can't get any hits with the blade which is why wedge fed blades are generally only fed one way and have the blade sticking out the other side so they can wedge feed the blade and use it normally.
-Greg (Not the one posting the CAD, if you were temporarily confused)
Unread 04-06-2007, 08:58
Exactly. one of the downfalls of having an exposed blade is that taking a side hit on it can do major damage. We felt that even with the possibility of not getting hits with the weapon we could do fine in the chance that their wedge was lower. After competing at one competition the biggest issue was that our lowest wedge (we called it the skirt) would get damaged and then it would be impossible to wedge anyway. Typically I build combat robots for one event, but I think I might re-build this one. If I do I will be removing one of the wedges making it one sided, and also putting a more powerful motor on the blade.
pic: Chaos Over the Ramp BandChick Extra Discussion 2 21-05-2006 20:43
Speaking of life-sized games.. Adam Shapiro Chit-Chat 5 14-05-2006 12:37
pic: Travel sized-ness Lisa Perez Extra Discussion 5 24-04-2005 23:08
pic: CD on a Super Sized monitor. Elgin Clock Extra Discussion 14 13-04-2005 01:48
pic: CHAOS 131 CD47-Bot Robot Showcase 12 01-03-2003 23:53
