Re: pic: pint sized chaos v2
Another advantage of the belts is that if the blade is stopped through either being damaged or having a bot wedged in/stuck on it, the belt will slip, which should keep the motors from stalling and save a good bit of money over time.
*sniff* It looks so pretty all assembled *sniff*
its a cute little robot, but arent the super heavy weights where its at? no way you can put a hpa system in that and get it to throw 340 lbs 10 feet up.
also im curious as to why a blade would be mounted on top of the robot?, to me it just seems harder, because you have to get the other guy on top before you do damage. by the way, very clean and good looking cad. |
-Greg (Not the one posting the CAD, if you were temporarily confused) |
Exactly. one of the downfalls of having an exposed blade is that taking a side hit on it can do major damage. We felt that even with the possibility of not getting hits with the weapon we could do fine in the chance that their wedge was lower. After competing at one competition the biggest issue was that our lowest wedge (we called it the skirt) would get damaged and then it would be impossible to wedge anyway. Typically I build combat robots for one event, but I think I might re-build this one. If I do I will be removing one of the wedges making it one sided, and also putting a more powerful motor on the blade. |
| pic: Chaos Over the Ramp | BandChick | Extra Discussion | 2 | 21-05-2006 20:43 |
| Speaking of life-sized games.. | Adam Shapiro | Chit-Chat | 5 | 14-05-2006 12:37 |
| pic: Travel sized-ness | Lisa Perez | Extra Discussion | 5 | 24-04-2005 23:08 |
| pic: CD on a Super Sized monitor. | Elgin Clock | Extra Discussion | 14 | 13-04-2005 01:48 |
| pic: CHAOS 131 | CD47-Bot | Robot Showcase | 12 | 01-03-2003 23:53 |
