Go to Post Keep your chin up, your safety glasses on, and don't let the magic smoke out of the electrical components and you'll do just fine :) - rsegrest [more]
Unread 06-07-2006, 00:50
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Edu Robot Camera Test Bed
Over the summer I wanted to play with the camera some more and also wanted to trying tracking other colors so I decided to make a little robot with the camera, this is what I have come up with:
I made my own adapter so i can attach regular RC batteries to the edu controller...
As for the light Kevin Meissner made me this beautiful tri-color led box:
The three buttons on the side are push-on push-off and active the according colors or red blue and green. There is also a standard female head phone jack on the box for power input.. we made adapter for a 9v battery and a wall adapter. The acuall colors of the light are much more rich and dispersed then how it looks in the pictures...
I plan on adding more sensors and other things soon...
The rest of the pictures can be found here...
http://s25.photobucket.com/albums/c94/bear24rw/
Unread 06-07-2006, 03:53
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Re: Edu Robot Camera Test Bed
I'm very, very much liking that LED box. Very cool little setup, good luck with it.
Chopsaw? Chopsaw.
Unread 07-07-2006, 10:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If you just need the camera to look around, you can also hook up the servos to the camera, and have it point itself. Then you can use any computer (or controller) with a serial port to give it commands. The entire communication protocol is documented.
One thing I was thinking about doing is making a CMUcam "terminal" interface. You give it commands, and it sends them to the camera. Ideally, could handle any mode, including streaming images and data. (I did actually start it, but I never finished.)
About the EDU bot, that looks very cool. Maybe I'll build something like that to carry my books around next year.
The LED display reminds me of a few projects I saw once on bigclive.com. (Warning: he's a British theater electrician/SFX guy and a pyro nut.) He's got a couple of PCB-based LED boards and such you might be interested in. (or maybe it's too advanced/bright for FIRST uses.)
Unread 07-07-2006, 12:01
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
I plan on running the camera off the EDU controller as well as the servos, in the same setup that was used by most team this year in FRC. Once I finish modifying the TTL chip to work with the EDU controller i will be able to start. The main purpose of this project is to track multiple colors as well as have a demo robot... Anyone have any other ideas for sensors or other interesting things i could do? I was thinking maybe putting a range finder sensor mounted right underneath the camera pan/tilt base...
Unread 07-07-2006, 22:16
987HighRoller's Avatar
987HighRoller 987HighRoller is offline
Vegas....Baby
AKA: Alex Sambvani
FRC #0987 (High Rollers)
987HighRoller has a spectacular aura about987HighRoller has a spectacular aura about
How would you go about doing this without labview? Also what software would be necessary, or would you have to make it yourself?
Team 987 - The High Rollers - Las Vegas, Nevada
2007 Las Vegas Regional Finalists
2007 Newton Champions
2007 Championship Winners! Thanks to 190 and 177
2008 IRI CHAMPS with 67 and 330
Unread 07-07-2006, 23:42
AKA: Jamie Bliss
FIRST distributed a Java-based GUI last year. It works, but it's not good.
The entire communication protocol is documented. It's primarily text-based (with a raw mode). Hyperterminal would work, except for the line endings; the camera uses CR-only (\r) line endings. (The options being Windows' CRLF (\r\n), Unix's LF (\n), and Mac's CR (\r).)
You could literally use something like
echo SM 64 | macendings > COM1
to control the camera, assuming the program "macendings" (converts lines to Mac-style) existed.
In one of the documents somewhere, it describes all the commands and the protocol and everything. I just don't know where off-hand.
Unread 07-07-2006, 23:50
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Kevin Watson has all the documentation on his website...
http://kevin.org/frc/
Unread 06-08-2006, 11:37
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Max, you're my hero. Just thought I'd drop that in.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
camera on edu controller Cuog Programming 2 06-05-2006 20:28
How to Test the Camera? ShortBang Programming 1 02-02-2006 19:54
Camera with EDU rc Morenoh149 Programming 1 15-05-2005 20:03
Camera test Guido470 Programming 0 11-01-2005 12:36
