Go to Post I will never forget Dean's opening lines: "I want you to know that I am here under protest. I believe that everything you are doing here is repugnant and ethically wrong. And now I am going to tell you why..." And for the next 35 minutes, that is exactly what he did. - dlavery [more]
Unread 07-08-2006, 22:31
Billfred's Avatar
Billfred Billfred is offline
How long do you keep the warranty valid?
So recently, I came into ownership of a new desktop PC, just for those odd things you can't accomplish on a Mac. I know there's a lot of things that can be done to a standard PC these days, and some of them (second optical drive, more RAM, maybe even a big side window for the fun of it) I'm inclined to add. (Well, I might skip the window.)
That said, I'm also interested in making sure that the hardware I already have works, and that anything that does go on the fritz gets fixed under warranty and not the Money From Billfred's Wallet Plan. I assume that there's folks out there who have been in a similar boat; how long did you hold off before cracking the case open?
Unread 07-08-2006, 22:34
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Re: How long do you keep the warranty valid?
45 minutes. My new graphics card came a few days before my computer did. Set up my computer, made sure everything worked. Popped that card in.
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 07-08-2006, 22:59
Andrew Blair's Avatar
FRC #0306 (CRT)
More or less, your hardware under warrenty will operate without problem- check it, and you're alright. What's less likely to work is add ons. I'm not even sure that all warrenties are voided by simply opening the case. Most likely, if your computer runs properly for a few days or weeks without issue, it will continue to. Problems will arise with improperly installed hardware, which won't be covered under warrenty anyways. Just read those manuals really, really carefully, and buy an anti-static bracelet.
-Sir Francis Bacon
-Albert Einstein
Keep FIRST Alive All Year Long: The Yearbook '06 yanksrock777 General Forum 0 26-03-2006 16:05
How about a REAL teaser? This one will keep you guessing... Travis Covington Robot Showcase 17 11-02-2006 12:03
pic: (447) How do YOU keep programmers out of the electronics? rufu5 Robot Showcase 34 27-03-2005 10:10
How do you keep a team from collapsing? pakrat Team Organization 10 21-10-2004 03:01
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
