Go to Post People do amazing things for stuff the have a passion for. - Foster [more]
Unread 05-08-2006, 21:44
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: Vex contest from Exploding Bacon
I am thinking of another rule change having talked to another engineer. He thinks is going to be too hard to go the whole round without going outside the hard path. We discussed of four points per object if you didn't go outside the path for that object.
The scoring amount stays the same but allows flexiblity of deciding to take the hard path for some and save time for others.
I think we are going to need a rules committee.
Doug Leppard
Unread 05-08-2006, 21:47
Billfred's Avatar
Billfred Billfred is offline
Would the four points be in addition to the twenty possible points for just driving within bounds, or instead of it? (I only ask because both add up to twenty points.) Personally, I'd not be so hot on it in the former case, as then you're pretty much required to take the hard path to get a decent score. And when do you genuinely begin going for an object?
And to answer your question, I'm in Columbia, SC, home of Steve Spurrier and the Palmetto Regional. It's only eight hours or so by car. (The fact that I seem to show up at nearly every FIRST event in the state of Florida is because I have easy access to transportation and no life. )
Unread 05-08-2006, 21:57
Originally Posted by Billfred
Would the four points be in addition to the twenty possible points for just driving within bounds?
No it is the replacement 4 points X 5 objects = 20 points. It works out the same if you never touch out of path.
But if someone did two objects without going out of path for just those two they would receive 8 bonus points. The old scoring even though they did two without going outside but then went straight for objects next time they would receive no extra.
How about you compete virtually? Film your runs post them on google video or something and we will enter you like everyone else. Will have to be by honor system. Run them the day before, someone else times it and is judge. You only get three runs like everyone else. Then when we compete when it is your turn we will play your round on video.
Doug Leppard
Unread 08-08-2006, 13:11
Onward through the fog.
Have you guys got a date yet?
(I have to come your way for business and was thinking of scheduling during that time frame. )
~ Helen Keller
(1880-1968)
Unread 08-08-2006, 14:41
wendymom's Avatar
wendymom wendymom is offline
Team Mom
AKA: Wendy Austin
FRC #5816 (Gra-V)
wendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond repute
The official date for this contest will be Sept. 9th. We don't have an exact location yet but assume its somewhere in Central Florida.
If you would like a full set of rules and a FAQ go to this site
https://www.mygcx.org/file/roboticsy...e%20V1%204.doc
Thanks
Unread 09-08-2006, 16:02
miketwalker miketwalker is offline
Robot Lifeguard
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
After recent events, it appears that the BiggestHobbit and I have found a way to enter this competition after all. Thus, I must ask a question/rule clarification.
Can the driver set the location of the objects in the starting location? If not, can we get a drawing of the spots in which these objects will be starting?
Chopsaw? Chopsaw.
Unread 09-08-2006, 16:43
Glad you and George will be joing us in this contest. Now for your question.
R 9. Player can arrange the objects to be grabbed in the starting box anyway they want as long as they do not touch outside the start area and are not stacked on one another or touch each other at the start of the game.
For full rules see:
So set them up as you see fit. I did this so we would not have to define where they are and make it part of the strategy.
Doug Leppard
Unread 09-08-2006, 17:32
Robot Lifeguard
For full rules see:
Wow, *hits self for not reading the manually thourougly* I thought I had read through it all and didn't see it. Thanks!
Chopsaw? Chopsaw.
Unread 09-08-2006, 19:19
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Another great 1902 event i will miss
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 09-08-2006, 19:53
Billfred's Avatar
Alright, I know you can have one person driving two robots simultaneously (according to the rules, at least). Two people can drive one robot simultaneously. Two people can NOT drive two robots. But enough citing of rules, on with the question.
Suppose that there is one robot that starts whole, then one part of the robot detaches from the other. One of these parts lacks any sort of electronics, motors, controls, or anything that could really make it considered a robot on its own merits; any movement from this part would require the other part--the real robot--to drive it. Could this arrangement be operated with two drivers?
Unread 09-08-2006, 21:22
Bill you come up with the most interesting questions, makes me wonder what is up your sleeve.
The idea behind this rule was that someone wouldn't come up with a robot that was really two robots and thus transport more objects faster. But actually this would be covered by the rule only one item can be transported at a time, so maybe the rule was unnecessary.
So as long as you are not transporting more than one object at a time and contain more than one object at a time then you are OK. Your definition of the second part of the robot in my mind is just an extension of the robot.
So to answer your question, it is OK.
Doug Leppard
Unread 09-08-2006, 21:25
Do you have a VEX kit available to you???
If so make a robot and compete virtually, send us the videos and we will enter them.
Doug Leppard
Unread 11-08-2006, 00:39
Git 'em!
No i dont have one :-(
Robot in 3 Days
Unread 17-08-2006, 21:18
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
say for instance i had a robot that did not touch the ground therefore avoiding the white lines completely and not touching them Is this going to be one on those "magical plane" kind of things or can i get realy creative. also...
would it be acceptable to dammage the objects to be retrived? say for instance. Harpooning them and realing them in.
and what constitutes "mostly vex" i could say that a superlight frame and drivetrain that was waterCut from CF witch is less than 50% of the overall robot weight is a robot that is "mostly vex"
Unread 17-08-2006, 22:29
We had a lengthly discussion about the flying through the air version and I wrote a FAQ that it fit the rules but not the spirit but would love to see it thus it was ok.
Mostly VEX thing bothered me, as I worked with the kids on the rules they did not want to nail it down more than that. I tried to do it with weight etc. but they didn;t want to. I think in future we may have a rule like FRC that has only VEX motors and MCU but few other rules. This was suppose to be for fun and learning.
Mine bot is built and it is almost totally out of VEX parts, I do have one piece part of the object grabber that is non-VEX. I used the VEX encoders even though I had non-VEX encoders on it before. I might put some non-VEX sensors like IR sensor.
WE just wanted a fun thing all of us VEX owners could do. This is a challenging contest and not that easy to pick them all up in the two minutes especially staying with the hard path.
Nothing in rules about damaging the objects. I know my first robot version would put dents in the empty can. So go ahead and destroy the objects.
Doug Leppard
pic: 1902 Exploding Field Stephen Kowski Off-Season Events 11 11-06-2006 12:23
pic: 1902 exploding wheel Stephen Kowski Extra Discussion 12 07-05-2006 22:30
Exploding dog Cody Carey Chit-Chat 9 16-03-2006 22:33
Black Battery Plug contest from AndyMark Andy Baker Kit & Additional Hardware 11 10-01-2006 21:37
Exploding 884s Alan Ing Electrical 16 02-03-2003 15:00
