Go to Post "In theory it will work" - Fuller [more]
Unread 08-08-2006, 02:09
Robots_R_Us Robots_R_Us is offline
Robots_R_Us is an unknown quantity at this point
How Many Have You Used?
In buying Vex parts from the Radio Shack sale, I am asking myself how many of what should I buy?
So how many motors, servos, sensors have you used on your Vex robots?
The Vex controller has 16 I/Os, 6 interrupts and 8 motor outputs available.
Thanks
RUS
Unread 09-08-2006, 08:49
Noggin Noggin is offline
Noggin is an unknown quantity at this point
Re: How Many Have You Used?
Personally, I'd get all I could. I'm using 2 starter kits, 2 hardware kits, extra metal from vexlabs, about 14 motors and 12 servos, 2 wheel kits, 1 encoder kit, 1 ultrasound kit (wish I had a few more) and several sprocket and gear sets. I have one bot that stays in working order, and use the rest of the parts to prototype other bots. I typically have 2-3 bots on the workbench at any given time, and the extra parts/motors make it easy to do so.
Of course, if your only looking for 1 good bot, then I'd say at least 6 motors on hand and 4 servos. You can build most any armature with a combination of those, and have spares just in case (I've toasted a servo already). I'd also get a few ultrasounds if you can find them, but the encoders are kinda useless because they don't record direction and they are bulky. You can code around the direction issue somewhat, but it still isn't optimal. The extra hardware and wheels are pretty handy too.
Hope this helps.
Unread 09-08-2006, 13:20
Hope this helps.
I too have thought that "just buy it all" was the solution but I am trying to stay within reasonable quantities even with the favorable Radio Shack pricing. Considering that the supplies are shrinking quickly, it would seem to about time to finish buying extras and so I am asking what is reasonable to keep on hand.
Any suggestions from anyone else?
Thanks
SRU
Unread 09-08-2006, 20:03
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
As far as motors and servos I'd go for eight motors and at least a couple of servos. Most robots I've built so far don't have much call for servos, but almost all of the bots have used at least 6, 7, or 8 motors. 2 or 4 motors for drive train, 1 motor for each axis of movement on any arm built, 1 or 2 motors for elevator/lifting mechanisms. The servos that have been used were usually for pan and tilt mechanism for sensors like the ultrasonics.
As far as hardware... 1 or 2 gear kits 1 to 4 chain and sprocket kits (and more chain from vexlabs ala carte!) at least 2 extra hardware kits (or a lot of ala carte metal from vexlabs!) 2 omni wheel kits and 1 to 2 tank tread kits (they make awesome ball harvesting conveyors just check out any pictures of 2005/2006 Half Pipe Hustle bots!)
Just my two bytes worth.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 10-08-2006, 00:43
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
I created a spreadsheet that lists all the parts available at the time I made the spreadsheet, and that used some seat of the pants fomulae to compute what to buy to in order to create a user-defined number of "complete" Vex robotics set-ups.
If I get a chance to review and tweak the spreadsheet soon (to insert changes due to lessons I have learned), I'll then figure out how to post it somewhere that folks can read or copy it for their own use.
Bottom line - No answer for you tonight; but a pretty good one soon.
Can you wait a few days? If not, send me a private message or an email.
Blake
Unread 12-08-2006, 11:24
Thanks for the responses.
I look forward to your spreadsheet results..the pricing at Radio Shack is just too good to pass up.
RRU
Unread 25-08-2006, 22:32
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
RRU
Sorry to have taken soooo long to get this posted. Obviously it is just my opinion(s).
If someone out there doesn't have access to Excel; and is dying to know my list of suggestions , send me a private email.
In the spreadsheet, notice that cell B3 is where you enter the number of robots you want to build (or it can be thought of as the number of users/students you want to equip).
Blake
How many drivers do you have? stephenthe1 General Forum 27 06-04-2005 21:25
How much of Gmail have you used? Yan Wang Chit-Chat 18 25-02-2005 11:22
How many buttons do you have? Bcahn836 Chit-Chat 12 01-09-2004 23:34
how many balls have YOU deflated? mattf Regional Competitions 28 15-03-2004 22:52
