Go to Post Suggesting change is one thing, implementing it is another. - JaneYoung [more]
Unread 09-08-2006, 21:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Vex Light Sensor
Basically, it is a standard CdS sensor which has low resistance in bright light and high resistance in darkness. Since it carries the current from the +5 supply to ground, the analog sensor has a value of about 0 in bright light, and about 255 in darkness.
The Inventors Guide on the item is here.
If you mean the specific characteristics of the CdS device used in the Vex product, I don't have that info, but I am sure Vex Labs would answer that in their forum.
Don
Unread 11-08-2006, 18:24
swe9 swe9 is offline
swe9 is an unknown quantity at this point
Don
I purchased a defective light sensor, so I have some graphs of the performance of both a good and a bad sensor. The good sensor returned values from 78 to 970 and had a sharply vertical responsde. The bad sensor was diagnosed as having a defective pull-up resistor and went vertical early but had a long exponential tail that kept it from settling on a value for a very long time. The low/high values could have been related to the amounts of light I had but seem representative of the range 0-1000 or 0-1024.
Angle Sensor for Vex tacman1123 Kit & Additional Hardware 11 02-07-2006 10:02
Vex Sensor Sample Code nonother FIRST Tech Challenge 2 08-05-2006 16:49
VEX Ultrasonic Sensor delay P1h3r1e3d13 Programming 4 28-03-2006 13:45
Light Sensor Type, Please Help! Alexander McGee Electrical 7 20-11-2004 21:48
How do light sensor(Banner) work? roberthan Programming 9 25-02-2004 14:05
