Go to Post your sense of humor - don't leave home without it. - JaneYoung [more]
Unread 10-08-2006, 13:54
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Labview GUI
has anyone tried the labview gui for the camera. I got it to work a couple of times, but it really struggles when it starts up. Pretty much everytime I start it does not recognize the camera.
So far i have...
-loaded it up in hyperterminal(all settings are correct)
-tried the java gui(works fine)
-set the labview gui to com 3, and manually typed in the firmware version(made it work both times)
but now it doesnt work. any ideas?
Collars up!
637
Unread 10-08-2006, 20:46
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: Labview GUI
So far i have...
the serial port on the camera is somewhat noise sensitive. i found that the first reset command sent to the camera is not always understood. so the software stops with an error message.
i modified one of the vi's to allow a retry after a failed reset. i now startup correctly every time.
this changed vi is "CMUcam2.vi". i inserted a while loop into the "reset camera" case structure.
if you are interested, i could send a copy of this vi by email (since i don't know how to attach a file to this forum).
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 10-08-2006, 20:53
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Labview GUI
the USB->RS-232 converters aren't that great. if you're using one you might want to try a computer which has a real rs-232 port.
also, i agree that the camera has a touchy serial port since it runs at such a high baud rate. try using a short serial cable, or a serial cable with a grounded shield.
personally i just used the black serial cable from the KOP and a serial port out the back of my good old IBM laptop.
I'll be happy to answer any other questions you might have.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 11-08-2006, 11:05
Booger's Avatar
FRC #0637
Re: Labview GUI
jerry w
yeah i would really apreciate that. I tried to add the loop myself but i was unable to get it to work because im not very familiar with labview. .
My email is sk8brder343@gmail.com
Collars up!
637
CMU Cam2 Java app (Help with Labview GUI) Team 1649 Programming 3 26-12-2006 14:25
LabView CMUcam2 gui drakesword LabView and Data Acquisition 6 28-01-2006 17:06
CMUcam2 LabVIEW GUI problems StevenB Programming 1 21-01-2006 03:08
CMUcam2 GUI Program nukem Programming 4 15-01-2006 03:19
Auto GUI VanWEric Programming 1 12-02-2003 01:46
