Go to Post When I first read this comic, I thought "Awww, how cute!". But then, thoughts of Karthik singing J. Lo's "Love Don't Cost a Thing" started running around through my head, and everything changed. - Travis Hoffman [more]
Unread 12-08-2006, 03:16
ocean_blue74 ocean_blue74 is offline
Junior Member
ocean_blue74 is an unknown quantity at this point
MPLAB...ERROR..Pls help..Thank You
I have just installed MPLAB IDE V7.40 with a MPLAB C18 Compiler,
but when I build all. there are error messages appeared.
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F4520 "Test.c" -fo="Test.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\MCC18\My Project\Test.c:1:Error [1027] unable to locate 'p18f4520.h'
C:\MCC18\My Project\Test.c:2:Error [1027] unable to locate 'delays.h'
MPLAB C18 v3.02 (demo)
Copyright 1999-2005 Microchip Technology Inc.
Days remaining until demo becomes feature limited: 60
Halting build on first failure as requested.
BUILD FAILED: Sat Aug 12 15:07:03 2006
Thank You.
I have make sure that Project>Buile Options>Project there is C:\MCC18\lib in the library path. But I do not know why the MPLAB cannot find the header.
Unread 12-08-2006, 06:33
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: MPLAB...ERROR..Pls help..Thank You
Try using MPLAP 7.2 or 7.22 i dont think 7.4 is supported...
Unread 12-08-2006, 10:45
The headers come from Project>Build Options>Project then the Include file path should be c:\mcc18\h
He or she is not using FIRST equipment, so don't have to worry about the versions.
Unread 12-08-2006, 11:50
Ken Leedle Ken Leedle is offline
College Student
FRC #0706 (CyberHawks)
Ken Leedle will become famous soon enoughKen Leedle will become famous soon enough
Make sure you include the header files in the header section of yourproject.mcp
If that doesn't work, try putting the header files in the same folder as your project.
Usually, I just need to have #include "p18f4520.h" at the beginning of the main.c file and it works just fine. I have used the the 18F4520 on one project without any difficulty using MPLAB 7.30 and C18 v2.40.
I would need more information about what you are trying to do to suggest anything else.
MPLab build error Derek t Programming 7 17-01-2005 09:33
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
MPlab error ryan_f Programming 9 24-05-2004 07:30
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
