Go to Post Sometimes our greatest failures lay the foundations for our greatest success. - =Martin=Taylor= [more]
Unread 12-08-2006, 12:27
MDelgado1989 MDelgado1989 is offline
MDelgado1989 is an unknown quantity at this point
Helicopter Project
Hey guys, being as I am new to this site, just want to quickly introduce myself. Names Miguel, reside in Miami, FL, 17 Years old, and I love electronics.
So I am going to be doing a project for school which is going to consist of programming a microcontroller to a RC Helicopter. What I would like to achieve is placing two Altimeters on the helicopter and program the Microcontroller to react to the elevations to keep the Copter balanced out in the air. If anyone can help me out in this and point me in the right direction as to which type of altimeters to use, I would GREATLY appreciate it. Thank you for your time
Take care
- Miguel
Unread 12-08-2006, 13:34
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Helicopter Project
Altimeters are not what you want to use - these are generally based on air pressure, or for very expensive versions on RADAR, but are not nearly sensitive enough to stabilize a helicopter.
Instead, consider using an accelerometer and a rate gyroscope. If I were going after this kind of project, I would probably want three axis versions of each.
The basic idea is to tell the controller what the readings on these sensors 'should' be, and then program it to control the helicopter such that the readings on the sensors 'are' where they need to be. The accelerometer is used for detecting large changes, and the rate gyro is used to detect small changes.
This is known as a closed-loop feedback system. There is a LOT of literature out there on this.
You have chosen an extraordinarily difficult project. A human with experience can have difficulty controlling a helicopter in hover; an autonomous system for the same might be considerably more complex than you think.
Not to discourage you - go for it! - but just have a realistic expectation that it's not easy.
Good luck,
Don
Unread 12-08-2006, 14:57
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
I am pretty sure he won't be using the altimeter to stabalize it. he would be using it to beable to tell what elevation he is at. once he is at tat elevation he would use the already preinstalled gyro on the rc heli to stabalize it. Probally from there he will write a PID loop to keep it at exactly the elevation he wants it to be at.
Unread 12-08-2006, 15:06
Thank you both for your repsonces, I greatly appreciate it. Sparks, that is exactly what I intended to do, have the altimeters read the elevation on both sides of the Copter and then have the pre-installed gyro react accordingly.
Don, I appreciate your comment very much, you explained it rather well. I have considered the difficulty of this project over and over but I have been flying planes for sometimes and although I have never really gotten into Copters, I have always wanted to and I figured what better way then to have some fun with this and learn a few things from it as well.
In conclusion, between both your comments, I believe the way I originally planned on doing it, which was the same way Sparks explained, having the altimeters read out the Altitude and having the Pre-installed gyro react accordinly, would be easier then the way you explained it Don. However, I would like both of your opinions on which way you guys recommend I go on this. Again, thank you for your time and responces, GREATLY APPRECIATED
Take care
- Miguel
Unread 12-08-2006, 18:00
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I think and easy thing to do would be buy a crappy transmitter for the heli, then gut it out. What you can do is hook that up to your micro controller and get some Digital->Analog converters and hook them up to all the pots. this way you can have you micro controller control it while you still have it hooked up to your computer and you can play with the values.
Second thing is make sure you have a transmitter handy while you are doing this and have the same crystal in it. This way if things get out of control you can turn off the one for you micro controller and take over manual control.
Third, get a trainer for the heli, this will allow you to still fly but not more then like 5-10 feet if that. Now if you crash it won't be as bad or as expensive.
Now depending on how much money you wanna spend you can put the transmitter with the micro controller on board the heli this way you will always have communication, but you can still get interference. they other way would to be to totally hack the whole system. write code for the gyro and motor controller and servos yourself, then have a radio modem so you can talk to your computer on the ground.
Unread 12-08-2006, 19:16
Thanks for the respond Sparks.
I have not bought the Heli yet, but I was thinking on getting an electric begginer ($100-130) which already comes with everything and is capable of taking off with some extra load on it just incase so weight does not become an issue, and I have extra transmitters lying around from my planes with extra crystals I can use.
Also, I have been researching on the net for altimeters and am indecisive on which ones to use. I am looking for a rather small one which would fit well on the computer, mounting is not an issue as I could easily find a way to mount it, but I am also looking for one which I can get to transmit back to the microcontroller so it can in return have it register out with the other Altimeter on the other side of the Copter and compare the two out to make sure that they are at even altitudes. This is not going to be a big scale project so they can be low level altimeters.
I was also considering using the Mini Copter (fits into palm) but was concerned due to its size that I might not be able to properly install any additional hardware on it and/or with a little extra weight, it might not be able to take off.
Thank you for your time and all your responces, you have been of great help to me man
Take care
- Miguel
Unread 12-08-2006, 19:18
Sorry for posting this now but I just realized since altitude is measured by air pressure and I don't plan on hitting anything over 20, mainly at 5-10, seems as though I am going to have to find a different route for this as I doubt it would pick up any difference in air pressure between 5 - 20 feet. Any ideas anyone? Thanks in advance
Take care
- Miguel
Unread 12-08-2006, 20:08
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
A word of warning: gyros have a tendency to spit out bad data occasionally, so i suggest having redundant sensors so you can tell if one is lying to you.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 12-08-2006, 22:36
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
-Q
The normal gyros in helis don't have a problem. as long as you read them at a fast enough rate some bad data shouldn't be a problem.
Unread 13-08-2006, 22:10
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
A few things to consider / be careful for -
Remote controlled helicopters are very challenging to operate. You should plan for lots of practice and lots of spare parts. Maybe look for a local RC club and see if someone there is flying helicopters and can give yousome pointers.
Many sensors do not have tight tolerances on their accuracy. Be sure to check the device specifications and be sure you will be able to develop the logic you are planning. The more sensitive and accurate the device, the more if costs. The smaller the range you want to measure the more accurate the device can be.
From the standards books, the ambient pressure at Sea Level is 14.696 psia.
At 10 feet, it is 14.6907, a difference of 0.036% or 0.0053 psi. To measure this requires extremely sensitive instruments. You will want to set up your program to look for a change in pressure from the starting point to help offset the accuracy of the device.
As a reference, a standard pressure transducer for a 'real' helicopter often carries an accuracy requirement of +/- 1% and might cost $1000. 1% accuracy means if the real pressure is 100 psia, the indicator might output anywhere from 99 - 101 psia and still be within it's accuracy capability.
Good Luck, sounds like a fun project.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 13-08-2006, 23:24
jakep jakep is offline
Software Engineer
AKA: Jake Poznanski
jakep has a spectacular aura aboutjakep has a spectacular aura about
You might want to check out http://autopilot.sf.net
Apparently, a project like this is quite a bit more complicated than you may expect. The people on that site spent quite a while getting to a hovering point. Software wise, they used an insane multiple input Kalman filter. They may have some good code examples to use though. (I adapted their Kalman filter for a simple 2 input gyro+DAA setup for use with the 2004 FIRST RC this summer)
Jake Poznanski
Programmer - Team 862 - Lightning Robotics
Microsoft MVP, 2005 - Windows - SPOT Technologies
http://www.spotdev.net
Unread 14-08-2006, 22:51
Hey guys, how you doing?
First off just want to thank all of you for all of your inputs and advices, I greatly appreciate it and it has helped me better understand what I am getting myself into and what I would need to do in order to have this project come out right.
Despite all the posts on the level of difficulty on this project, I have decided to still go on with it and try to expirement a little and just have some fun with it.
I have also decided to go with either the ADXL213 - ±1.2g Dual Axis Accelerometer with Duty Cycle Modulated Outputs or the Memsic 2125 Dual-axis Accelerometer. I did some research on it and seems as though these would be a good choice for me to use. Although I have decided to go with one of these accelerometers, I am still looking at which Microcontroller would be best for this. Please keep in mind I have little knowledge on programming but I have a neck for computer programs and I pick up VERY fast on these kind of things.
Again, thank you all very much for your inputs/opinions/comments. I greatly appreciate all the help and support
Take care
- Miguel
Unread 15-08-2006, 03:35
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Try using a ultrasonic range sensor pointed downward to get an accurate height. Though a microcontroller on the heli will be required.
http://www.sparkfun.com/commerce/pro...roducts_id=639
I don't know about amtel but I have been pretty successful with picMicrochips(go with 18 series so you can program smilar to the RC)
Can anyone explain to me the difference?
Unread 15-08-2006, 07:03
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
If you're planning on keeping the helicopter inside, a novel way to track your position would be with the CMU cam pointed at a colored target. Indoors, under controlled conditions, you could also use one of the Sharp IR proximity sensors to measure your altitude.
Here are some comments based on personal experience. Your ideal platform would be a large fixed-pitch helicopter like the Lite Machines Corona. There are only four channels to control and it can carry some weight if you upgrade to a brushless motor. A small fixed pitch helicopter, like the Honey Bee or Dragonfly, doesn't have enough lift to carry the extra gear required. You will have to upgrade to brushless motors and lithium polymer batteries, which turns your $100.00 toy into a $350.00 money pit. I don't know how it would work in reality, but in theory you could use a futaba heading-hold gyro on each axis to keep the helicopter stable in roll, pitch, and yaw. It won't keep the helicopter in place, but it should keep it stable on each axis. Those are about $100.00 each, so you're up to about $650.00. Your primary control inputs would be the throttle, which controls altitude, the ailerons, which controls side/side, and the pitch, which controls forwards/backwards.
Here is another way to approach it. Get a coaxial helicoper like the ESky Co-Co Lama or Blade CX. Put a brightly colored target on the nose that that you can track with the CMU cam. Build a robot that can manipulate the heli transimitter and build a robot that "flys" the helicopter. Based on the camera feedback you'd be able to determine its altitude and orientation. If the target is square then the height would correlate to the range and the width would correlate to its orientation. You control loop would need to try and keep the nose pointed at the camera at all times, then apply throttle/aileron/pitch to keep it in one place. Those helis are very stable and almost fly themselves.
Unread 15-08-2006, 14:20
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Atmel AVRs are relative newcomers to the field. While they don't have the same grip on the market as PICs they are fairly popular. They're much easier to get in to for hobbyists as their open architecture allowed the development of cheap programming hardware, as well as free C compilers based on the GNU GCC toolchain. They have decent capabilities and are quite capable chips.
They always have a strong support following at: http://www.avrfreaks.net/
If you'd like to know more, drop me a PM
Matt Krass
The Helicopter Game Aaron Lussier Chit-Chat 32 13-08-2006 19:03
pic: Apache Helicopter Animation negfrequency Extra Discussion 12 28-06-2006 19:07
Helicopter Dude joemcool Championship Event 4 01-05-2004 01:01
pic: Helicopter CD47-Bot Extra Discussion 2 20-02-2004 18:37
Helicopter propulsion archiver 2001 20 23-06-2002 22:59
