Go to Post I do know a lot of teams need to be saved from themselves. - Karthik [more]
Unread 12-08-2006, 23:13
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Custom Application
I am looking for someone who can program in a language like VB, or java, or c for computers. I need a program written that on the serial port will just output a simple string of a few characters. and maybe something that slides (like a on screen linear pot) to change values from 0-255.
I have no idea where to look to find someone who can help me or if anyone is willing to help me.
Please let me know
thanks
Unread 13-08-2006, 00:23
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Custom Application
Please let me know
thanks
You know what I am currently working on something exactly like that.
It can simulate all 4 joysticks. Move a button around in 2D space and it acts like a joystick.
Still working on simulating pwms using sliders and a ton of other features.
I keep making it more complicated by the minute as I keep thinking of new features to add.
I am doing it Visual C++ 2005 .NET 2. What I am doing is a long way from finished but a for now a couple of sliders shouldn't be too hard to do.
I can't test anything right now because I don't have access to a the OI/RC.
This is just one of the things I have been working. It simulates almost everything that can be done on a single OI port(except some switches and leds). I am planing on sending the data for all the ports about 20 times a second over the program port(don't want to overwhelm the RC).
Name:	GUI control.JPG
Unread 13-08-2006, 00:42
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
It wouldn't be for the system we use, it is going to be to control my robotic arm once I finish it. I don't need anything like PWM just a serial output at 9600 baud, and sending characters. simple as that.
Unread 13-08-2006, 03:49
6600gt's Avatar
AKA: Lohit
Are you going to type these characters that are to be sent?
For starters download Visual C++ 2005 Express Editon form microsoft.com and set it up. .NET 2 is still beta so the app is going to have to compiled on your computer(I believe).
Unread 13-08-2006, 05:32
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
No the characters will not be typed, Basically I am just sending these commands to my servo controller. So to start off I want an app that will send the strings for the simple mode which is just 0x80 0x<servo number> 0x<servo position>
Due to the servo numbers being able to go up to 255 the servo position does not have a valid value of 255, so it is 0-254.
I am attaching a simple drawing of what I would like, the picture alone is self explanatory for the rest.
When you hit the set button it sends the string.
Name:	custom app thing.JPG
Unread 13-08-2006, 11:22
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
VB 2005 Express is free here. VB 2005 has a very simple serial communication control. When you register VB 2005 you can download an e-book that has some very basic information on VB. Read that book and you should be able to figure how to do this.
If you have any questions PM or e-mail me and I will help you any way I can.
EDIT: I am curious are you referring to the robotic arm from the "Build Your Own Humanoid Robot"? Your drawing looks like the VB6 program from that book.
Hope this helps
Eric Haskins
haskinseric@hotmail.com
Eric Haskins KC9JVH
Unread 13-08-2006, 13:14
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Being a true LabVIEW weenie, I'd highly recommend borrowing the LabVIEW Student Edition CD from last year's kit of parts (I think that you can also download an eval version from www.ni.com). It's very easy to configure a serial port and generate a few bytes in a loop based on a slider.
For reference, I've attached a pair of VIs that I'd created for last year's competition to control a Mini-SSC (purchased from Jameco, provides 8 PWM outputs controlled via serial port). "Mini SSC.vi" is the "GUI" and "write to Mini SSC.vi" is the low-level "function" that writes data from a serial port.
Good Luck!
Unread 13-08-2006, 14:18
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
hmmm.....it jsut so happens that is the same servo controller I am using! how'd you guess?!
I have never even heard of that book, everything I am doing I am desgining myself.
Unread 13-08-2006, 17:28
6600gt's Avatar
AKA: Lohit
I can make something like that if you want to test it out...
Does the data stream have to periodic sent to the controller?
Unread 13-08-2006, 22:39
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
The data stream only has to be sent once.
Unread 14-08-2006, 00:41
gobeavs's Avatar
gobeavs gobeavs is offline
linux advocate
AKA: Ross
None #1425 (Wilsonville Robotics)
gobeavs will become famous soon enoughgobeavs will become famous soon enough
Send a message via AIM to gobeavs
Didn't .NET do away with legacy communication protocol support? Was getting the serial port to work easy?
"Never in the face of human conflict has so much been owed by so many to so few."
- Winston Churchill on the RAF in WWII
Unread 14-08-2006, 02:58
6600gt's Avatar
AKA: Lohit
.NET2 has built in support for serial port...drag and drop
Unread 14-08-2006, 04:13
gobeavs's Avatar
linux advocate
AKA: Ross
Ah, ok. Thanks for clearing that up.
Unread 15-08-2006, 00:48
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
ok so I have someone helping me with this right now.....but we are having some troubles sending the right data over the serial port. Is there anyone who can help?
Unread 15-08-2006, 15:56
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Are you using .NET 2? And what code do you have so far to try to send it out...?
Application Process Nick Seidl College Teams 2 11-09-2003 17:23
New member application Aaron Lussier General Forum 30 06-09-2002 22:28
Application Notes V1_0 archiver 2000 0 24-06-2002 00:08
Application Notes V1.0 Brandon Martus Off-Season Events 0 05-10-2001 13:52
FIRST Scoring Application Justin Off-Season Events 1 20-06-2001 16:45
