Go to Post Learn the ideas, look up the formulas. The other way round will drive you mad - Joe Johnson [more]
Unread 13-08-2006, 18:46
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Trying to figure out the Segway...
I would imagine the speed limiting function further complicates the balancing algorithm.
When you're approaching the maximum speed for the key you're on, or when you're otherwise approaching the maximum power the motors can put out (like when facing a strong headwind) the motors sort of put on a burst of acceleration to get the base of the Segway further forward in relation to the handlebars, so that if you wanted to accelerate any more you'd have to lean right over the handlebars (which would prompt a stick-shake warning).
So I'm going to leave speculation on how it works to people who are more qualified to answer.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
How can you figure out robot speed?!?! gnirts Programming 7 01-04-2006 13:05
how do u figure out the torque req'd to move a robot? Salik Syed Technical Discussion 11 03-11-2004 08:12
Can't figure out auton mode TangoBravo1318 Programming 1 20-02-2003 10:06
A little more complicated, but I'll figure it out... Erin General Forum 12 01-06-2001 14:35
Trying out this place David Kelly Chit-Chat 16 01-06-2001 12:11
