Go to Post I wouldn't mind dropping a banana peal or throwing a red turtle shell at other robots, but that's the rules! - SpaceOsc [more]
Unread 13-08-2006, 22:10
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Helicopter Project
A few things to consider / be careful for -
Remote controlled helicopters are very challenging to operate. You should plan for lots of practice and lots of spare parts. Maybe look for a local RC club and see if someone there is flying helicopters and can give yousome pointers.
Many sensors do not have tight tolerances on their accuracy. Be sure to check the device specifications and be sure you will be able to develop the logic you are planning. The more sensitive and accurate the device, the more if costs. The smaller the range you want to measure the more accurate the device can be.
From the standards books, the ambient pressure at Sea Level is 14.696 psia.
At 10 feet, it is 14.6907, a difference of 0.036% or 0.0053 psi. To measure this requires extremely sensitive instruments. You will want to set up your program to look for a change in pressure from the starting point to help offset the accuracy of the device.
As a reference, a standard pressure transducer for a 'real' helicopter often carries an accuracy requirement of +/- 1% and might cost $1000. 1% accuracy means if the real pressure is 100 psia, the indicator might output anywhere from 99 - 101 psia and still be within it's accuracy capability.
Good Luck, sounds like a fun project.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 13-08-2006, 23:24
jakep jakep is offline
Software Engineer
AKA: Jake Poznanski
jakep has a spectacular aura aboutjakep has a spectacular aura about
You might want to check out http://autopilot.sf.net
Apparently, a project like this is quite a bit more complicated than you may expect. The people on that site spent quite a while getting to a hovering point. Software wise, they used an insane multiple input Kalman filter. They may have some good code examples to use though. (I adapted their Kalman filter for a simple 2 input gyro+DAA setup for use with the 2004 FIRST RC this summer)
Jake Poznanski
Programmer - Team 862 - Lightning Robotics
Microsoft MVP, 2005 - Windows - SPOT Technologies
http://www.spotdev.net
Unread 14-08-2006, 22:51
MDelgado1989 MDelgado1989 is offline
MDelgado1989 is an unknown quantity at this point
Hey guys, how you doing?
First off just want to thank all of you for all of your inputs and advices, I greatly appreciate it and it has helped me better understand what I am getting myself into and what I would need to do in order to have this project come out right.
Despite all the posts on the level of difficulty on this project, I have decided to still go on with it and try to expirement a little and just have some fun with it.
I have also decided to go with either the ADXL213 - ±1.2g Dual Axis Accelerometer with Duty Cycle Modulated Outputs or the Memsic 2125 Dual-axis Accelerometer. I did some research on it and seems as though these would be a good choice for me to use. Although I have decided to go with one of these accelerometers, I am still looking at which Microcontroller would be best for this. Please keep in mind I have little knowledge on programming but I have a neck for computer programs and I pick up VERY fast on these kind of things.
Again, thank you all very much for your inputs/opinions/comments. I greatly appreciate all the help and support
Take care
- Miguel
Unread 15-08-2006, 03:35
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Try using a ultrasonic range sensor pointed downward to get an accurate height. Though a microcontroller on the heli will be required.
http://www.sparkfun.com/commerce/pro...roducts_id=639
I don't know about amtel but I have been pretty successful with picMicrochips(go with 18 series so you can program smilar to the RC)
Can anyone explain to me the difference?
Unread 15-08-2006, 07:03
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
If you're planning on keeping the helicopter inside, a novel way to track your position would be with the CMU cam pointed at a colored target. Indoors, under controlled conditions, you could also use one of the Sharp IR proximity sensors to measure your altitude.
Here are some comments based on personal experience. Your ideal platform would be a large fixed-pitch helicopter like the Lite Machines Corona. There are only four channels to control and it can carry some weight if you upgrade to a brushless motor. A small fixed pitch helicopter, like the Honey Bee or Dragonfly, doesn't have enough lift to carry the extra gear required. You will have to upgrade to brushless motors and lithium polymer batteries, which turns your $100.00 toy into a $350.00 money pit. I don't know how it would work in reality, but in theory you could use a futaba heading-hold gyro on each axis to keep the helicopter stable in roll, pitch, and yaw. It won't keep the helicopter in place, but it should keep it stable on each axis. Those are about $100.00 each, so you're up to about $650.00. Your primary control inputs would be the throttle, which controls altitude, the ailerons, which controls side/side, and the pitch, which controls forwards/backwards.
Here is another way to approach it. Get a coaxial helicoper like the ESky Co-Co Lama or Blade CX. Put a brightly colored target on the nose that that you can track with the CMU cam. Build a robot that can manipulate the heli transimitter and build a robot that "flys" the helicopter. Based on the camera feedback you'd be able to determine its altitude and orientation. If the target is square then the height would correlate to the range and the width would correlate to its orientation. You control loop would need to try and keep the nose pointed at the camera at all times, then apply throttle/aileron/pitch to keep it in one place. Those helis are very stable and almost fly themselves.
Unread 15-08-2006, 14:20
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Atmel AVRs are relative newcomers to the field. While they don't have the same grip on the market as PICs they are fairly popular. They're much easier to get in to for hobbyists as their open architecture allowed the development of cheap programming hardware, as well as free C compilers based on the GNU GCC toolchain. They have decent capabilities and are quite capable chips.
They always have a strong support following at: http://www.avrfreaks.net/
If you'd like to know more, drop me a PM
Matt Krass
Unread 15-08-2006, 14:32
Mike Shaul's Avatar
Mike Shaul Mike Shaul is offline
FRC #0065 (Huskie Brigade)
Mike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant future
Originally Posted by Matt Krass
Atmel AVRs are ....
I agree with the AVR option. I've started using them for the same reason(s). Free C compiler, lots of application notes, software examples (assembly and C) and development hardware is cheep!
You may want to look into the mega AVRs since they have hardware multipliers which may be handy for processing multiple PID loops quickly (not necessary, but nice).
By far the best proof is experience. - Sir Francis Bacon
Unread 15-08-2006, 16:06
Hey guys, once again, thank you for all your comments.
Before I get into target operation and manuevering (sp), I would first like to get the Copter to atleast hover on its own under the programmed codes.
Running it through my head, I figure what I would need for this, simply to get the Copter hovering on its own, would be the Copter, ADXL213 Dual-axis Accelerometer or Memsic 2125 Dual-axis Accelerometer, whichever I decide to use to balance the Copter out, and the Microcontroller along with all the programming sofrware. If there is anything I am missing, please let me know. Again, thank you all
Take care
- Miguel
Unread 15-08-2006, 16:23
hovering is actually the most challenging aspect of this auto pilot project.
When the HC starts to hover the downdraft of the blades will push the air straight down. After a few seconds the air will start to swirl in a donut pattern, the air that was being pushed down goes outward, then back up, and is then sucked through the blades again.
the result is, the air at the center of the HC developes a downward velocity. In order for the HC to maintain its height you must apply more and more pitch/power.
So you are going to need a way to measure altitude in order to hold a fixed altitude while hovering.
Unread 15-08-2006, 16:34
6600gt's Avatar
AKA: Lohit
[quote=
So you are going to need a way to measure altitude in order to hold a fixed altitude while hovering.[/QUOTE]
IR or Ultrasonic range sensors...
Thats the problem I had with 16 series pics when I started working with pics: no free C compilers. So I started using 18F series pics and used the RC code as a guide to make mine work. After a while I finally got a 18f458 to run a servo!
Unread 15-08-2006, 21:18
Rookie Year: 1942
Actually there are two phases of hover - HIGE and HOGE
Hover IN Ground Effect and Hover OUT of Ground Effect.
What Ken describes is IN ground effect - the ground is causing the air to recirculate and can cause turbulence, but it can also require less power to hover in this condition.
Hover OUT of ground effect means the helicopter is high enough that the air dissipates and the ground has no effect on the rotor system.
Chris Fultz
Unread 15-08-2006, 21:45
I dont think it is limited to the ground effect altitude.
I found this on a website - it appears to be a run-away sort of thing, once it starts to happen you cannot lift out of it, unless you move forward out of the ring of airflow:
According to the Federal Aviation Administration (FAA) Rotorcraft Flying Handbook, pages 11-5 to 11-7, Vortex Ring State (Settling with Power), "Vortex ring state describes an areodynamic condition where a helicopter may be in a vertical descent with up to maximum power applied, and little, or no cyclic authority. The term 'settling with power' comes from the fact that the helicopter keeps settling even though full engine power is applied. In a normal out-of-ground effect-hover, the helicopter is able to remain stationary by propelling a large mass of air down through the main rotor. Some of the air is recirculated near the tips of the blades, curling up from the bottom of the rotor system and rejoining the air entering the rotor from the top.
However, when the helicopter begins to descend vertically, it settles into its own downwash, which greatly enlarges the tip vortices. In this vortex ring state, most of the power developed by the engine is wasted in accelerating the air in a doughnut pattern around the rotor. In addition, the helicopter may descend at a rate that exceeds the normal downward induced-flow rate of the inner blade sections. As a result, the airflow of the inner blade sections is upward relative to the disc. This produces a secondary vortex ring in addition to the normal tip-vortices. The secondary vortex ring is generated about the point on the blade where the airfoil changes from up to down. The result is an unsteady turbulent flow over a large area of the disc. Rotor efficiency is lost even though power is still being supplied from the engine."
Unread 15-08-2006, 22:33
None #0116
I haven't seen it with the model helis, but with a fixed-pitch model you have little or no control when dropping altitude because the blades aren't spinning fast enough to maintain cyclic authority. If you hover at about 20' then try to land the tail will drop and the cyclic turns to mush. You'd have to be pretty good to drop straight down.
Unread 15-08-2006, 21:16
None #0116
Take care
- Miguel
At minimum you will need three gyros and three accellerometers. It took me about 3 hours of flying time to hover a battery pack without crashing. That's flying time, not counting time spent waiting for spare parts. Micro helis are so cheap becase they make money on the spare parts. As Ken was saying, any change in roll or pitch requires an increase in throttle. The best analogy I've seen is balancing a marble on a piece of glass. I'm not going to say it can't be done, but it will be very difficult. As I said in a previous post, it's not just controlling the heli, its being able to carry your sensor and processor payload too. A micro heli can only handle a couple of extra onces of weight.
Go to http://rcgroups.com and visit the micro heli forum. There is a sticky with a PDF called the "Electric Helicopter Beginner's Guide". Essential reading.
The Helicopter Game Aaron Lussier Chit-Chat 32 13-08-2006 19:03
pic: Apache Helicopter Animation negfrequency Extra Discussion 12 28-06-2006 19:07
Helicopter Dude joemcool Championship Event 4 01-05-2004 01:01
pic: Helicopter CD47-Bot Extra Discussion 2 20-02-2004 18:37
Helicopter propulsion archiver 2001 20 23-06-2002 22:59
