Go to Post Just like it is not all about the robots, it is not all about winning the Chairman's Award. - Paul Copioli [more]
Unread 13-08-2006, 22:26
Re: Trying to figure out the Segway...
actually the balancing algorithm on a Segway is not much different that the cruise control on a car. Sensors detect the orientation of the platform and the rate at which it is starting to tip, and the motors respond to keep the Segway level
just like the cruise control on a car adjusts the throttle to hold the car at a constant speed - the Segway holds a constant level.
I dont have personal knowledge of the algorithm used, but you can make feedback systems tight or loose. If its tight it will quickly cancel out all error. On the Segway, that would mean as soon as you shifted your weight (lean forward) it would instantly compensate to stay level, moving very little.
I think the feedback on the Segway is selectively loose - when you lean forward it compensates to keep you from falling over, but not completely, so the platform ends up moving forward - sorta like its perpetually falling
Unread 14-08-2006, 20:48
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
It sounds like all of you have given up. Why would you do such a thing?
I wonder if Dean Kamen knows how much this bugs other people? I imagine he would laugh if he knew how much this BUGS ME!!!
Yes, I realize that there are many, many redundant systems in the Segway, but I still think it would be interesting to build my own. I'm definitely talking to the team about building one. What's the worst that can happen.....?
Aren't signatures a bit outdated?
Unread 14-08-2006, 21:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You'll be many hundreds if not thousands of dollars poorer with a pile of hardware that doesn't do a darn thing. And you may have people injured requiring thousands of dollars in medical bills. You did say worst.
Unread 14-08-2006, 21:13
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Test it with monkeys. Works for the cosmetic industry, so why can't it work for a robotics team? That would possibly solve the thousands of dollars in medical bills, they'll turn into vet bills. Heh... funny me.
But yeah, building your own Segway could prove rather expensive and not worth it. That's just my opinion though.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 14-08-2006, 21:15
if you want to know how the segway works, get the patent and read it.
The patent must fully disclose the operation of the system, because that is what is being patented, not just what the system does, but how it does it.
For this reason it is necessary for the patent to fully explain how it works. Otherwise, whenever someone else came up with a similar idea, Segway could claim "thats how we do it, so we have a patent on that...."
your patent only covers your invention as you describe it. If someone else can come up with a different way to make a system that performs the same function, they are not violating your patent.
How can you figure out robot speed?!?! gnirts Programming 7 01-04-2006 13:05
how do u figure out the torque req'd to move a robot? Salik Syed Technical Discussion 11 03-11-2004 08:12
Can't figure out auton mode TangoBravo1318 Programming 1 20-02-2003 10:06
A little more complicated, but I'll figure it out... Erin General Forum 12 01-06-2001 14:35
Trying out this place David Kelly Chit-Chat 16 01-06-2001 12:11
