Go to Post a determined team can accomplish miracles. - Wayne C. [more]
  #31   Spotlight this post!
Unread 15-08-2006, 12:02
jakep jakep is offline
Software Engineer
AKA: Jake Poznanski
jakep has a spectacular aura aboutjakep has a spectacular aura about
Re: CIM Voltage and Motor Suggestions
So what exactly is a flexible coupling and coupling spider? What function does it perform?
Bearing pillow blocks are the blocks of aluminum that have a bearing in the middle right? And then you mount them to your frame and the shaft goes through the bearing, right? This supports the load then, I assume.
You say that "With the flexible coupling, the shaft out of the drill won't support anything at all.", but then why do you still need the bearing blocks?
Jake Poznanski
Programmer - Team 862 - Lightning Robotics
Microsoft MVP, 2005 - Windows - SPOT Technologies
http://www.spotdev.net
  #32   Spotlight this post!
Unread 15-08-2006, 12:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Here's a link to some on McMaster Carr
Drill shaft goes in one side, wheel shaft goes in the other. As you can see, the coupling istelf is only held together if it's pushed from both sides. If you try to bend it or anything it'll just fall apart. So. You mount the drill with that clamp on one side, and then you'll need two bearings supporting the wheel's shaft on the other side.
  #33   Spotlight this post!
Unread 15-08-2006, 13:57
Software Engineer
AKA: Jake Poznanski
Ahh, so it's sort of a protection mechanism?
Jake Poznanski
  #34   Spotlight this post!
Unread 15-08-2006, 14:46
That and you can use it to more easily couple your direct drive shaft. You can thread one half the coupling and screw it on to the drill, and then use the left hand screw to hold it on. The spider means you can still easily couple it to the other half of the coupling and your wheel shaft.
Large CIM motor Wayne Doenges Motors 3 06-03-2006 21:24
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
CIM motor components natis Motors 4 13-01-2006 11:04
CIM-MOTOR source Andrew Schuetze Motors 6 18-05-2005 11:57
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
