Go to Post ...our football team was a state champion, but i don't see -them- going to atlanta and winning there! :D - Sam Lipscomb [more]
Unread 15-08-2006, 12:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: CIM Voltage and Motor Suggestions
Here's a link to some on McMaster Carr
Drill shaft goes in one side, wheel shaft goes in the other. As you can see, the coupling istelf is only held together if it's pushed from both sides. If you try to bend it or anything it'll just fall apart. So. You mount the drill with that clamp on one side, and then you'll need two bearings supporting the wheel's shaft on the other side.
Large CIM motor Wayne Doenges Motors 3 06-03-2006 21:24
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
CIM motor components natis Motors 4 13-01-2006 11:04
CIM-MOTOR source Andrew Schuetze Motors 6 18-05-2005 11:57
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
