#16
Re: Helicopter Project
You may want to look into the mega AVRs since they have hardware multipliers which may be handy for processing multiple PID loops quickly (not necessary, but nice). |
#17
Hey guys, once again, thank you for all your comments.
Before I get into target operation and manuevering (sp), I would first like to get the Copter to atleast hover on its own under the programmed codes. Running it through my head, I figure what I would need for this, simply to get the Copter hovering on its own, would be the Copter, ADXL213 Dual-axis Accelerometer or Memsic 2125 Dual-axis Accelerometer, whichever I decide to use to balance the Copter out, and the Microcontroller along with all the programming sofrware. If there is anything I am missing, please let me know. Again, thank you all Take care - Miguel |
#18
hovering is actually the most challenging aspect of this auto pilot project.
When the HC starts to hover the downdraft of the blades will push the air straight down. After a few seconds the air will start to swirl in a donut pattern, the air that was being pushed down goes outward, then back up, and is then sucked through the blades again. the result is, the air at the center of the HC developes a downward velocity. In order for the HC to maintain its height you must apply more and more pitch/power. So you are going to need a way to measure altitude in order to hold a fixed altitude while hovering. |
#19
[quote=
So you are going to need a way to measure altitude in order to hold a fixed altitude while hovering.[/QUOTE] IR or Ultrasonic range sensors... Quote:
#20
Go to http://rcgroups.com and visit the micro heli forum. There is a sticky with a PDF called the "Electric Helicopter Beginner's Guide". Essential reading. |
#21
Hover IN Ground Effect and Hover OUT of Ground Effect. What Ken describes is IN ground effect - the ground is causing the air to recirculate and can cause turbulence, but it can also require less power to hover in this condition. Hover OUT of ground effect means the helicopter is high enough that the air dissipates and the ground has no effect on the rotor system. |
#22
I dont think it is limited to the ground effect altitude.
I found this on a website - it appears to be a run-away sort of thing, once it starts to happen you cannot lift out of it, unless you move forward out of the ring of airflow: Quote:
#23
| The Helicopter Game | Aaron Lussier | Chit-Chat | 32 | 13-08-2006 19:03 |
| pic: Apache Helicopter Animation | negfrequency | Extra Discussion | 12 | 28-06-2006 19:07 |
| Helicopter Dude | joemcool | Championship Event | 4 | 01-05-2004 01:01 |
| pic: Helicopter | CD47-Bot | Extra Discussion | 2 | 20-02-2004 18:37 |
| Helicopter propulsion | archiver | 2001 | 20 | 23-06-2002 22:59 |
