Hooking up a motor to Vex controller
Okay, I have a DC motor, 1.5-3Volt. I want to hook it up to my Vex controller. Do I need a speed controller? If not, how do I do this?
BTW, I now know how to hook the motor up to a battery pack and a switch. Just random information. |
Re: Hooking up a motor to Vex controller
first off the vex is approx 7 volts so you need a separate battery. you also would need a pwm motor controller that runs on 3 volts...
/forest |
Oh... okay. Well, okay. I guess I'll stick with the setup I have. A battery hookup through a switch to the motor. I could have sworn I read somewhere that I could use a motor like that.
| VEX radio controller | Greg Needel | FIRST Tech Challenge | 3 | 06-05-2007 15:09 |
| IR on the Vex controller? | jgarbers | FIRST Tech Challenge | 0 | 18-04-2006 14:07 |
| Programming VEX Controller | HRobotics | Programming | 4 | 21-03-2006 23:25 |
| Hooking up Controller to computer for programming. | Dragon45 | General Forum | 3 | 30-01-2003 00:22 |
| hooking up sensors to controller? | Oakridege_665 | Technical Discussion | 5 | 21-01-2002 14:55 |
