Go to Post I'll admit that the events at Epcot were pretty nice, but they too had their problems. . . You were at the mercy of the weather, and Disney hasn't figured out how to control that yet. - Kevin Sevcik [more]
Unread 16-08-2006, 15:40
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Mecanum Drive Technique
Originally Posted by Tytus Gerrish
mecanum works the same way as an Omni-directional Holonomic drive. its just that the rolers are at 45° instead of the whole wheel. simple as that.
As Madison said, Holonomic and Mecanum drives can actually be quite different. For instance, the rollers don't even have to be at 45º (different angles will alter the amount of energy that is used when going different directions. A 45º angle results in the movement in both the X and Y axis being equal, but any other angle they would not be).
Basically, a mecanum drive's angled rollers directs some of the energy of motion sideways, and depending on the direction and speed (the vector) of each wheel, you can move your robot in any direction.
Unread 16-08-2006, 20:42
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
45º is simply a rule of thumb you can do it at whatever angle you would like you could even actuate the angle to get some diffrent properties out of the preformance.
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Maxi Block Wiring Technique Al Skierkiewicz Electrical 0 06-02-2006 08:40
Is this a valid technique? (Color application to metal) Elgin Clock Technical Discussion 8 09-06-2004 21:33
Programming technique.. archiver 2001 3 24-06-2002 04:02
