Go to Post Science and Technology is like the tide in the ocean, it raises all ships together, whether they're an engineering ship or a manual labor ship. - Doc Wu [more]
Unread 16-08-2006, 01:31
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Mecanum Drive Technique
Can anyone help me understand the technique behind making a mecanum drive system?
I know there are mecanum wheels that are reversed, and all that, but how would they be set up and driven to drive sideways and diagonally and all that fancy stuff?
Thanks
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 16-08-2006, 08:14
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Mecanum Drive Technique
mmmm kinematics.....try reading this paper to start with, it should get you on your way....http://www.chiefdelphi.com/media/papers/1836
Unread 16-08-2006, 08:43
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Here are a couple of links on how you'd go about programming the stick...
holo-drive math
...and more
...and there's more out there, too....just search on holonomic and omni-wheel
Eric
Don't PANIC!
S. P. A. M.
Unread 16-08-2006, 10:34
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
mecanum works the same way as an Omni-directional Holonomic drive. its just that the rolers are at 45° instead of the whole wheel. simple as that.
Unread 16-08-2006, 10:36
Thank you all so much.
This will definately help.
Unread 16-08-2006, 14:27
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The programming required to achieve the same motion varies pretty significantly, however, between holonomic and mecanum drivetrains. The principles by which they operate are similar, but the implementation is different.
--Madison--
...down at the Ozdust!
Unread 16-08-2006, 15:40
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
As Madison said, Holonomic and Mecanum drives can actually be quite different. For instance, the rollers don't even have to be at 45º (different angles will alter the amount of energy that is used when going different directions. A 45º angle results in the movement in both the X and Y axis being equal, but any other angle they would not be).
Basically, a mecanum drive's angled rollers directs some of the energy of motion sideways, and depending on the direction and speed (the vector) of each wheel, you can move your robot in any direction.
Unread 16-08-2006, 16:19
Not so. Program-wise, a standard omniwheel mounted at 45 degrees works exactly like a mecanum wheel with its rollers at 45 degrees.
Unread 16-08-2006, 16:31
Madison's Avatar
FRC #0488 (Xbot)
Yes, that's correct. The programming only differs if you consider 'forward' to be a direction parallel to one pair of omniwheels in a holonomic platform. Thanks for pointing out my oversight.
--Madison--
Unread 16-08-2006, 20:42
AKA: Ty
45º is simply a rule of thumb you can do it at whatever angle you would like you could even actuate the angle to get some diffrent properties out of the preformance.
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Maxi Block Wiring Technique Al Skierkiewicz Electrical 0 06-02-2006 08:40
Is this a valid technique? (Color application to metal) Elgin Clock Technical Discussion 8 09-06-2004 21:33
Programming technique.. archiver 2001 3 24-06-2002 04:02
