Go to Post If I understand what you're saying, you don't understand very far. - Alan Anderson [more]
Unread 18-08-2006, 09:37
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: A new drivetrain Idea?
Originally Posted by Arefin Bari
when you open the hinges and wheels are 180 degrees, wouldn't each side try to fight against each other?
I was thinking the same thing. However, What if the "hinges" were in opposite corners, the center of each side, or even if there were more than two hinges? While I, too, would wonder if the complexity gives you a distinct advantage over other designs, this is certainly inventive and interesting.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 18-08-2006, 09:46
It would be interesting to see a robot with two sets of these, effectiving spreading your drive wheels to a wider and longer wheel base when open
and changing the 'front' of the robot by 90º
Unread 18-08-2006, 10:02
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
In 2005, 648's robot could extend to give it more stability. I don't remember the exact stats but it almost doubled it's short side. How we got it to do this was just lock the back wheel and power the front two wheels and then it would lock into place with servo actuated hooks. When we when back to get into the box all we would have to do was lift the hooks with the servos and squish back together.
This concept made me immediately think of that robot.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 18-08-2006, 10:32
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I personally think that it is a very innovative idea which can amaze some people if properly designed and built. This design doesn't have to be used particularly for a FIRST robot, but can be used for demos and offseason projects.
As far as the rule <R08> goes (after the start of the match the robot may expand up to a maximum volume of 60 inches by 60 inches by 60 inches)... there have been teams who have made their base shorter than 38x28 (bot had riggers and so forth but after full extension they were in the size limit). The problem Ben pointed out earlier is one of the very important component of this design (if you are building this chassis for a FIRST robot according to last year's rule) but there are ways to avoid the chassis extending more than 60". I do agree with you Ben where you said it's a very complex design, but how cool would it be to see something like this on a FIRST field.
... keep going Cody, show us your next step to this design.
p.s. - I am still waiting to hear from Baker, Neun, and Copioli about what they think about this design.
Unread 18-08-2006, 10:34
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
I'm not trying to crash your idea but I think that it would have to be thought out just a little bit better. I am a fan of creating new drive systems. It would be hard to convince me that this would work, and what are the advamtages to having this over a typical swerve drive?
-Josh Murphy-
Unread 18-08-2006, 10:53
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Well that's interesting!
If you had a particular design problem you were trying to solve, I'd say you might want to open it up to other possible solutions. But it SEEMS like you are floating an idea to see what other people thing - which is great! Being creative for creative's sake is great - you don't always need to be engineering a solution to a problem.
Let's say this never becomes a FIRST robot drivetrain - I bet it still gives you ideas on some other FIRST mechanism. Or - it made me think of this... an unpowered cart to carry stuff (maybe a FIRST robot) that folds up for easy shipment and storage in the pit. BAMN - already a use for FIRST.
Thanks for sharing!
Brian Graham
Unread 18-08-2006, 12:32
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Originally Posted by Ben Piecuch
Based on the drawings I've seen in this thread, isn't this type of design going to violate rule <R08>
"...In other words, after the start of the match the robot may expand up to a maximum volume of 60 inches by 60 inches by 60 inches."
Granted, this was a specific rule for 2006, but you have to keep such rules in mind for future designs. And now to comment on the design, I'm not quite sure how this is an advantage or improvement over a crab or mechanum design. It seems much more complex to make a completely hinged system.
BEN
While Creating concepts for the unknown Rules of the FUTURE. One can not limit themselves to the rules of the PAST.
Clearly Cody thought of this as a pure elemental idea not tied to any competition robot team competition or set of rules. it is simply an idea. I say go for it Cody. don't worry about any rules, you don't have any. just make it up as you go along and just Tailor your ideas to your needs when you chose to pull it out of your arsenal and use it
Unread 18-08-2006, 12:55
one possible applicaiton of this winged-drive train idea
in several seasons we had to pick up objects/balls from the floor. Making a robot that is open on one side leves it vulnerable (you cant have an opening and a bumper at the same location) and you have a tradeoff between the footprint of the robot, and the max possible size of the opening
but if your drive train swung out into a wider footprint (on all four sides) you could have a significant advantage
plus, after you collect objects from the floor, you could close up again, to make the robot more robust, and compact, if there was an advantage to that configuration.
Unread 18-08-2006, 13:00
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
Wouldn't the casters drag on the floor/carpet while you are moving sideways?
hey, fin
What about a ball caster? They reduce the movement that a normal caster has. Page 1224 of Mcmaster Carr is a threaded stem ball caster.
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Unread 18-08-2006, 13:03
AKA: Ari
Originally Posted by punkrawker303
hey, fin
Team 108 used them back in 2005, I didn't like them too much because that robot was used on the field as well as outside to do programming. All the sand and stuff from the carpet got stuck with the ball and later on the ball started to get jammed. Mike, I thought you knew me better, I don't like to use casters.
Unread 18-08-2006, 13:06
AdamHeard's Avatar
Lead Mentor
I love that Idea with mecacums.
Imagine this scenario. There is a similar style goal with a light that you use the camera to track. You open up to the right angle based on the distance you calculate from the camera, and the robot squares of for you. All you do is hit left and right on the joystick to move in an arc around the goal. If you move forward or back the robot will adjust the angle and square off again, pretty much guarunteeing a perfect arc around the goal. Also, you would have the ability to drive in all directions normally.
I wish I could convince my team to try this :/. But I can barely get anyone to listen to my idea of doing team 25's wheels.
Keep it up, I'm really interested now.
Unread 18-08-2006, 13:12
hey, fin
all castors can pivot or roll in any direction. Thats what a castor is.
If it cant go sideways, its called a wheel! iº]
Unread 18-08-2006, 13:34
Billfred's Avatar
Billfred Billfred is offline
If it cant go sideways, its called a wheel! [ºiº]
This may be true, but a ball caster doesn't have to pivot before it can roll (something we found out the hard way when our autonomous kept just missing the mark in 2004). It's just one less thing to have to worry about in programming; we've had enough to worry about this year!
Unread 18-08-2006, 14:21
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
There is really no need to create such a complex drive system. It would create so many more problems in the weight catagory as well as for your team programer. Another problem is during a match your robot will be extremely voulnerable to be redirected and trapped. If anpohert teams robot is next to yours while you are switching modes your robot will be spun around using its own power from the motors opening then closing the hindge. If your in the open possition and something gets into your robot while your closing it will jam up your robot and make you waste preciouse time to fix the problem. If you are looking for high manuverabiliy then i suggest using mechanum wheels.
Unread 18-08-2006, 14:29
AdamHeard's Avatar
Lead Mentor
Are you talking about the design that uses omni wheels, or the 4 wheel mecacum design? The 4 wheel mecacum design seems better because it will always be omnidirectional and still be able to travel in an arc.
Imagine: Locking onto a goal, facing it, adjusting to the right arc angle. Then hit left/right on the stick to travel on the arc. Hit forward or back to move closer (mecacums remember) or farther, the angle readjust automatically. You can juke forward, back, left and right instantly without looking away from the goal. I doubt next years game will have the same situation though :/
new award idea ewankoff General Forum 16 05-04-2006 14:08
Questions about an Idea for a drivetrain. Radiator251 Technical Discussion 21 29-01-2006 13:11
Crazy drivetrain idea lukevanoort Technical Discussion 7 26-10-2005 21:19
Crazy NEW Idea! Kyle Love Championship Event 14 07-11-2004 16:50
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
