Go to Post I found another student once at a Cross Country meet because she was wearing a team shirt. I must say, I was surprised. I should start wearing my team shirt around more often. - TheBoulderite [more]
Unread 18-08-2006, 22:07
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Problem changing channel on 2006 OI
We are at a festival this weekend with teams 63 and 291, and neither 63 nor ourselves can change our channel from 40. We have done this numerous times before, and even looked up the procedure again to check ourselves... and we can't see anything wrong with what we are doing, yet there has to be something, because it is not working. We tether the bot, switch all the necessary dips on the OI, and then reset everything; in the past, this has worked, but now it doesn't. Any suggestions as to what we might be doing wrong?
Thanks in advance,
-Cody
Unread 18-08-2006, 22:14
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Problem changing channel on 2006 OI
Have you tried tethering, setting the dip switches, and redownloading the master code and then the user code?
/dan
Unread 18-08-2006, 22:22
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
/dan
Nay... the programming laptop is down at the moment, is there any way we could get around doing this?
Unread 18-08-2006, 22:27
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Hmm.......none that I can think of......unless you have a standard FIRST field setup .......this is how I've always done it.
Unread 19-08-2006, 00:43
Originally Posted by Cody C
...We tether the bot, switch all the necessary dips on the OI, and then reset everything; in the past, this has worked, but now it doesn't. Any suggestions as to what we might be doing wrong?
When you say "all the necessary dips", which ones do you mean? The leftmost switch of the team number must be flipped in order to enable the alternate radio channels.
(I'm pretty sure that even though the OI shows a team number greater than 2048, the actual team number on the transmitted data stream hasn't changed, so you shouldn't really have to use the tether. But I might be wrong.)
Unread 19-08-2006, 00:58
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Ahhh, Thank you.... for whatever reason, when I read that paragraph over and over, I replaced MSB with LSB in my head... Thank you =-)
Problems Changing Channel on Yellow Dongle BaysianLogik Control System 6 22-02-2005 19:00
Changing Fields? Steve W Championship Event 8 08-04-2003 19:37
Changing Chairman's Jacqui Sutton Chairman's Award 1 03-04-2003 09:47
Changing gears archiver 2000 1 23-06-2002 23:26
::CHANGING SERVERS:: Brandon Martus General Forum 5 21-12-2001 10:33
