Go to Post Viva La FIRST Revolucion! - phrontist [more]
Unread 22-08-2006, 07:27
TomS TomS is offline
TomS is an unknown quantity at this point
Data From C++ GUI to Excel/Notepad, Application Trouble
"Hi,
I need to get data from a C++ application to a spread sheet or notepad file, has anyone any idea how to do this. I have access to programme source code but not sure where to start."
Content hosting - Fixed rate loans
Unread 22-08-2006, 15:19
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Data From C++ GUI to Excel/Notepad, Application Trouble
Originally Posted by TomS
"Hi,
Are you using Visual C++? If yes, then download and install Visual C++ 2005 Express Edition form microsoft.com.
Unread 22-08-2006, 16:23
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
"Hi,
A "notepad file" would be easier to output to than a spread sheet, which would require you to research the file-format.
To output to a file from a C++ program, you have a few choices.
1) The program can output all of the data you need to a command line, and then when you run the program run it as:
your_program.exe > file_with_data.txt
The ">" tells the command line to take all of the text that was outputted to stdout (which is what cout and printf do) and put it into the file following the ">" sign, in this case "file_with_data.txt"
2) There is a standard library for outputting to files for C++ from within the program. It's called 'fstream', so you would put "#include <fstream>" at the beginning of your program.
To use this, you would need to make an fstream object at the beginning of your program, and then use it like "cout" to output data. Here's an example:
fstream file_output; // create an 'fstream' object
file_output.open("my_filename.txt"); // open the file 'my_filename.txt'
//whenever you want to output data:
file_output << "This goes into the file";
//and at the end to close the file:
file_output.close();
You could google 'fstream' or 'file i/o tutorial' for more/better help.
Hope that was clear, good luck
Unread 30-08-2006, 22:21
Jared Russell's Avatar
Taking a year (mostly) off
If you want to output to a spreadsheet, look into CSV. Excel and most other spreadsheet tools can read it automatically.
It's basically just like writing to a text file, but inserting commas and carriage returns to denote rows/columns.
live input/output to/from application MarkH Programming 3 06-04-2006 01:43
Getting data from the robot mfwit LabView and Data Acquisition 1 19-02-2006 20:07
How do I declare a string and pass it from a Visual Basic GUI to a C++ DLL? complete Programming 0 14-01-2006 17:35
Color Picker gone from GUI. Firestorm Programming 2 14-02-2005 21:54
Program to copy list of files from Windows explorer as text into an application? Elgin Clock IT / Communications 6 30-12-2004 21:23
