Go to Post “Coming together is a beginning; keeping together is progress; working together is success.” - Henry Ford - hiyou102 [more]
Unread 22-08-2006, 07:23
TomS TomS is offline
TomS is an unknown quantity at this point
How I can execute Javascript into Perl?
"I don't know how I can execute an event of Javascript into a link in a program in Perl.
This event of JavaScript have executed a function that return a HTML page.
Anybody know how I can it?
Is it possible do it this?:
$datos=$datos.""<a href='"" . $me . ""?C=OFERTAS2&EMPRESA="".$empresa_param.""&NREF="" .$nref.""' onMouseOver=""linkFTecnica(nref2)"">"";
What is bad in this code?
Thank you very much. "
Content hosting - Fixed rate loans
Unread 22-08-2006, 07:28
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: How I can execute Javascript into Perl?
Are you trying to get the Javascript to execute inside of perl program or just trying to have the perl program output javascript? I'm a tad confused.
Unread 22-08-2006, 15:39
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Is the 'linkFTecnica' function in the javascript, or is it a perl function?
If it is a perl function, then you need
onMouseOver=" . linkFTecnica(nref2) . ">";
if it's a javascript function, then the quotes around that are being seen by perl, and it thinks that linkFTecnica(nref2) is not part of the variable "$datos"
Hope this helped.
Unread 22-08-2006, 16:35
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Do you get an error that looks something like this?
Bareword found where operator expected at test.pl line 1, near "'"" . $me . ""?C=OFERTAS2&EMPRESA="".$empresa_param.""&NREF="".$nref.""' onMouseOver"
        (Missing operator before onMouseOver?)
Bareword found where operator expected at test.pl line 1, near """linkFTecnica"
        (Missing operator before linkFTecnica?)
String found where operator expected at test.pl line 1, near ")"""
        (Missing operator before ""?)
syntax error at test.pl line 1, near "'"" . $me . ""?C=OFERTAS2&EMPRESA="".$empresa_param.""&NREF="".$nref.""' onMouseOver"
This would be because you aren't creating your string properly. If you're trying to append a string to $dateos, you want your code to be like this
# assuming linkFTecnica is a perl function
$datos = $datos . "<a href='" . $me . "?C=OFERTAS2&EMPRESA=" . $empresa_param . "&NREF=" . $nref . "'onMouseOver=" . linkFTecnica(nref2) . ">";
-- or --
$datos = $datos . "<a href='$me?C=OFERTAS2&EMPRESA=$empresa_param&NREF=$nref' onMouseOver=" . linkFTecnica(nref2) . ">";
-- or --
# Assuming that linkFTecnica is a JS function (which it probably is)
$datos = $datos . "<a href='$me?C=OFERTAS2&EMPRESA=$empresa_param&NREF=$nref' onMouseOver=linkFTecnica(nref2)>";
The difference between my code and yours is that you're using "" for some reason to open and close your string. Are you trying to escape them or something? If so, you want to use \" instead of ""
Also, remember that when you put a scalar variable within double quotes that it gets expanded.
$x = "test";
$y = "This is a $x";
results in $y being "This is a test". If you get into problems like this
$x = "test";
$y = "This_is_a_$x_with_underscores"
you will need to resolve it in one of the following ways
$x = "test";
$y = "This_is_a_" . $test . "_with_underscores";
$y = "This_is_a_${x}_with_underscores";
Hope that points you in the right direction.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Javascript and .ocx lantian329 Programming 2 12-12-2005 23:59
javascript ate my cereal! steveg IT / Communications 2 29-03-2004 01:10
Javascript onclick link concatination Trashed20 Website Design/Showcase 10 04-06-2003 11:18
How much time do you put into building your robot Wayne Doenges General Forum 16 29-01-2002 19:30
