Kevin Watson and programming VEX in MPLAB
Who has programmed a VEX in MPLAB using Kevin's code? I am currently looking at the gyro code and wondering how Kevin's code works on a VEX.
Re: Kevin Watson and programming VEX in MPLAB
Open up the vex source code, and import kevinsfile.c and kevinsfile.h. Follow the setup procedure in the documentation. It should "just work."
Make sure you include the old pic headers (pic8250.h) if you are using 2006 code. |
I don't see kevinsfile.c or h on his page. http://kevin.org/frc/ Where do I find that? |
| Programming Vex w/ MPLab | dababyjebus | FIRST Tech Challenge | 27 | 25-04-2008 09:11 |
| Trouble using Kevin Watson's Serial Code with Vex user API | StargateFan | Programming | 3 | 13-01-2007 15:42 |
| Vex Programming with MPLAB and IF loader | Joohoo | Programming | 3 | 27-07-2006 18:18 |
| MPLAB Help, programming and compiling | RedOctober | Programming | 2 | 23-12-2005 17:46 |
