Go to Post When a team is composed completely of robot builders and technical people that team cannot exist just like a company cannot exist if it is only made up of engineers. - Garret [more]
Unread 24-08-2006, 18:20
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Mac G4 render farm
Originally Posted by addictedMax
and intels are good at things like rendering
Usually because the software is optimized for them...otherwise AMDs are not bad either...
Unread 24-08-2006, 19:50
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Originally Posted by 6600gt
Clock does not determin performance. That is why AMD beat Intel until now. the new Xeons are far more advanced and do more per clock than those G4s ever could. The Xeons can do more instructions per clock than those G4s ever could.
The old 3GHz P4s could do 10,000 MIPS.
Clock speed tells nothing about its MIPS or the performance of the processor
No they don't, the clock speed determines how many instructions per second. Period. Just because the new Xeons are more "advanced" doesn't change the definition of megahertz. The farm of G4s do more instructions per clock (not considering other system specs, just processor) than the Xeon's does, even if you take into consideration the four logical processors...
The average studio quality scene takes an hour per frame to render.If the Xeon takes an hour to render it, and the G4s take 3 hours each, then they still win... because in 3 hours the Xeon will have rendered 3 frames, and the G4s will have rendered 36.
In standard rendering programs (like the default scan-line renderer for 3dSmax), three of the four cores in a quad-core processor are wasted, because the renderer only uses one. I have no Idea about the standard renderers for Maya, but I wouldn't imagine they could be much different.
The Xeon computer would have to be more than 36 times faster than its G4 predecessor to have better rendering capabilities, and that just isn't plausible.
Unread 24-08-2006, 20:50
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Edit: double post.
Unread 24-08-2006, 21:01
Animator
Team Role: Animator
Agreed, other things influence the performance of a computer than clock. buswidth allows more simultaneous calculations, and therefore increases the net work done. Dual cores act essentially as a tiny renderfarm on one chip, and do the same thing. It's not about the clock, men, there are more important things...
Just a nitpick, a one hour Xeon scene would probably take a 400MHz processor five or seven hours to do, probably more. We strive for accuracy...
dont dismiss. The discussion is about what computer will render faster, not processor. ram and graphics cards play just as important a role in this as the processor.
Scanline does go faster with dual cores, BTW. And mental ray adds buckets for more cores. watch a dual core render in MR. you'll see TWO boxes going at it.
Unread 24-08-2006, 21:15
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Ok, I'm sorry for my innaccuracies, in 7 hours, the xeon would only have 7 frames done, and the render farm would have 36... the Xeon still looses, which is the point I was trying to make.
By your own admission in the first quote in this post, the render farm will still render faster. Don't sidestep.
I didn't mention a word about Mental Ray.
Now onto what I actually said, and not what was brought to the table by people other than myself. Can you show me documentation that says the default Scanline renderer provided with Max uses all the processors present in a computer? because I have timed a render on our quad-core 2.8 at the school, and It did no better than my single-core 2.8 at home.
Unread 24-08-2006, 21:57
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
codyc, mhz has very little to do with how much gets done. IPC, or instructions per clock cycle is what determines how much work a processor can do per mhz. just look up some benchmarks of a lower clocked processor like a dothan (pentium m) or conroe (core 2 duo) and compare them to a higher clocked processor like a prescott (pentium 4). you will find that a conroe at 2 ghz can compete with a pressler (pentium d) at 5+ghz. A lower clocked chip with a very high IPC is better then a higher clocked chip with a low IPC. high MHZ = lots of heat, and wasted energy. that is why the pentium 4 turned into a disaster while the athlon 64 kicked butt.
there are still many other factors such as bandwidth, latency, cache, ARCHITECTURE etc.
unless you are comparing the mhz speed of the exact same chip, you are doing a hopeless apples to oranges comparison. Even if you are comparing the same chip, performance does not scale linearly to mhz. a 4ghz chip is not going to be twice as powerful as the same chip clocked at 2ghz.
Unread 24-08-2006, 22:51
Animator
Team Role: Animator
Who's sidestepping? It's a valid point.
I did. It's also a valid point. Sorry if MR kicks scanline out the window.
Thank you, this is what i ws trying to say. It's not the clock, or how many processors you have. It s the overall setup.
Unread 25-08-2006, 00:41
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
In this particular setup, however... the g4s would far out perform the Xeon.
Unread 25-08-2006, 00:51
Happy Birthday! theycallhimtom theycallhimtom is offline
AKA: Tom Conerly
FRC #1540 (The Flaming Chickens)
theycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura about
Send a message via AIM to theycallhimtom Send a message via MSN to theycallhimtom
Sure the render farm would be faster than one single computer. But consider other things. There needs to be a network so add the cost of that. The space for 36 computers, power costs etc. Then the time to setup and keep the cluster running would be a pain.
Over the summer I had an internship at a local college. My teacher had a 48 computer cluster (each one with dual Pentium 3s) it was a pain to keep everything running. After a few years the motherboards stopped working so they had to be replaced by hand. etc.
Unread 25-08-2006, 08:04
Chris27's Avatar
AKA: Chris Freeman
well for $4000 you could make 6 computers based on an amd x2 or a core 2 duo that will easily outperform all of those macs.
Unread 25-08-2006, 14:35
addictedMax's Avatar
addictedMax addictedMax is offline
The No Man
AKA: Tom L
FRC #1094 (Channel Cats)
addictedMax will become famous soon enough
atlon 64's even
Hi I'm Addicted to 3ds Max, I don't need help though not at all
Unread 25-08-2006, 14:43
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
This is true, but the clock speed is all we have to go in in this scenario... we know nothing more about the Mac G4s than the clock speed, so we can't say which has more ram or a better video card. All we can do is assume, and as stated before... we strive for accuracy. Making calculations based on clock speeds when nothing else is known about a computer is in no way a mistake, It's working with what was given to solve a problem that was presented.
About the heat caused by Pentium 4s, I don't know if you're much into researching the reasons behind problems, but I am. The extra heat of a Pentium 4 is due to the fact that they require more core voltage to operate. My 2.8 Pentium 4 requires a core voltage of 1.8v while my brothers athlon equivalent only asks 1.6v, and yes mine runs hotter, but it beats his in all of the benchmarks. If there is more energy going into the core, then more energy will have to come out, and alot of it will be heat, but every bit as much energy will will still be going into the practical functions of the processor. High megahertz does not equal lots of heat, High core voltage does. High megahertz equals faster ability to process data.
I have searched and searched for the benchmarks That state that a
5.0 Ghz looses to a 2.0Ghz, and I just can't find them... mind pointing out where you found them?
I sure hope you didn't take those numbers out of thin air...
and as for the 6 computers that would beat the 36, you may be absolutely correct, but that has nothing to do with the question that was asked, so don't present it like a point in your argument.
As for the render wall costing more in energy and labor than the single computer... The 46 extra cents a day (when you have the machines running) and having to replace hardware every couple of years is worth it
when you have a deadline coming up and your singe Xeon can't render your project fast enough.
This is starting to feel pretty hostile, So I'm done.
-Cody C
Unread 25-08-2006, 15:22
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
Originally Posted by Cody C
This is true, but the clock speed is all we have to go in in this scenario... we know nothing more about the Mac G4s than the clock speed, so we can't say which has more ram or a better video card. All we can do is assume, and as stated before... we strive for accuracy. -Cody C
Just wanted to point out that some of the specs are listed in the product description. All of the G4's have 128 MB of RAM and some have Dual Head or DVI videocards ( I am assuming these are the cards that came with the computer so they are not too advanced.)
And Cody, there is really no reason to leave this discussion. After all, we are just discussing a theoretical question about which system will render faster
David
Unread 25-08-2006, 16:00
Animator
Team Role: Animator
I think i am done as well, after this last post.
Much is known. The specs of a xeon and of the G4 are only a google search away.
Xeon:
http://www.2cpu.com/articles/99_1.html
G4:
http://www.dealtime.com/xPF-New_Tech...z_7MXMG400_200
As per the benchmarks, I did them myself. I was speaking for what i have done and seen. Such were my observations, and many of my other computer friends have had similar experiences. I apologize if my using this information was offensive to anyone.
Unread 25-08-2006, 17:02
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Another thing to look at the G4's is do they support OSX, they may be limited to OS 9.2 which could limit you to a somewhat volatile OS and not be able to get compatible software.
pic: 269's Westin Battery Farm Ricky Q. Extra Discussion 4 02-05-2006 07:16
single or a rendering farm? BuddyB309 3D Animation and Competition 17 09-02-2006 11:16
Test render Matt Hallock 3D Animation and Competition 7 26-01-2004 13:17
Setting up a render farm Ryan Dognaux 3D Animation and Competition 3 16-01-2004 00:26
Render FullScreen ? archiver 2001 0 24-06-2002 02:00
