Go to Post I'm sure someone somewhere worked [I]really hard[/I] on this and I congratulate them for the attempt. Unfortunately, its one of those things that should be taken down and recorded in the company journal as a bad idea. - Katie_UPS [more]
Unread 26-08-2006, 23:51
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Inventor help
Please only respond if you have an idea that wasn't mentioned, or if you have a helpful link.
Well the problem started after i installed windows SP1 and 2. Every time i try to do ANYTHING in inventor it crashes. I think it's having a problem seeing the license which causes it to crash. I've tried un-installing it, reinstalling it, downloading updates, deleting the license from the registry, un-installing SP1 and 2, and doing a system restore to an earlier time, nothing has worked. If no one can come up with any solutions i think I'll just have to reload the OS.
thanks in advance to anyone who helps out.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 26-08-2006, 23:54
CraigHickman
Posts: n/a
Re: Inventor help
First question: are you running a multiple user system, and using inventor from a non admin used? (I had that problem)
Second question: is your graphics card supported? (this can be found out at the autodesk site)
Unread 27-08-2006, 02:44
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Inventor help
Did you try installing it after you installed sp2? If it was the license then it probably wouldn't even start. You might have to clean your registry(be careful).
Mine crashes to desktop after it does a couple frames of heavy rendering when I am trying to render an animation.
Unread 27-08-2006, 13:50
[527]phil's Avatar
Alumni
AKA: Phil
Re: Inventor help
no I'm not running multiple users, and i updated the drivers but same problem . And what exactly should i delete from the registry?
Unread 27-08-2006, 15:14
6600gt's Avatar
AKA: Lohit
Re: Inventor help
Try CCleaner when you don't have Inventor installed. I haven't had any problems with it but be careful with the registry. You might as well try this before you reistall.
First backup everything important on the comp before you do anything.
What errors does it give you?
Unread 27-08-2006, 23:12
[527]phil's Avatar
Alumni
AKA: Phil
Re: Inventor help
It gave me a bunch of registry reading errors when i installed it again, so i went through the registry to look, and for some reason those files had restricted access, so i changed it and the installation worked. but it still wont load and it gives me an error "the instruction at '0x01229db4' referenced memory at '0x012a39e8'. the memory could not be 'read'". think a disk defrag might work?
Unread 28-08-2006, 00:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Inventor help
No. Defragmenting will not restore damaged data; it will merely re-arrange it on a drive to allow for better access and slightly increase the available free space.
Besides, you're describing an error that occurred in RAM, not on disk. This could be indicative of a memory defect, but that's not too likely unless you're seeing this sort of error in many other programs as well. (Since they share the same RAM, after all.) Absent any physical damage, this sort of error is typically due to a bug or an incompatibility in software, not hardware.
As for Windows XP SP1 and SP2, just leave the service packs installed. You really shouldn't expose an XP RTM (i.e. no service pack) computer to the internet for any appreciable length of time, given the exploits that exist for old vulnerabilities. Look at it this way: if Autodesk products only worked on three-year-old versions of XP, nobody would use Autodesk products.
Also, don't bother with registry hacks or cleaners; unless the utility is written to account for a specific Inventor issue (and, realistically, it's probably not), it's very probably going to do nothing to help, and may well cause damage.
Which version of Inventor are you using? Have you installed the latest service pack for it?
Consider contacting Autodesk.
Unread 28-08-2006, 02:30
[527]phil's Avatar
Alumni
AKA: Phil
Re: Inventor help
I'm using inventor 10, and i tried the service packs. nothing worked. And thats what was puzzling me, it was referencing a ram error but i don't get that error with any other program so i assumed it was something else. guess I'll be doing a fresh windows install soon.
Unread 28-08-2006, 07:28
Re: Inventor help
Has anybody tried going to the Autodesk website for help. Although their search isn't the gretest, you may find exactly what you are looking for. One of our installs failed in a similar way to your description. It turned out there was an incompatibility with the screen driver.
Unread 03-09-2006, 23:40
[527]phil's Avatar
Alumni
AKA: Phil
Re: Inventor help
It's most likely the graphics card, unfortunately according to the autodesk site my video card (nvidia 6200) is only supported in inventor 11. The sad part is that I'm running inventor from my 500 MHz laptop with 192Mb ram and a 16 Mb video card, but can't run it on a 2Ghz, 1GB ram, and a 128 Mb video card computer. So until i guess I'll be buying another Radeon 9550 soon.
Unread 04-09-2006, 09:10
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Re: Inventor help
Unsupported chipsets seems to be a recurring problem with older copies of Inventor.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 05-09-2006, 13:23
[527]phil's Avatar
Alumni
AKA: Phil
Re: Inventor help
Thanks for all the assistance guys, but it turns out that it wasn't a graphics problem. My sister got a virus that norton couldn't remove (beware of myspace layout creator websites!!!) so i reformatted my computer. Inventor works fine now and i think Star wars galexies was to blame.
Inventor Help bjimster1 Inventor 9 14-01-2006 17:01
Inventor Help CraigHickman Inventor 11 06-01-2006 18:06
Inventor Help PSeid-991 Inventor 29 08-03-2005 10:56
inventor help Michael Leicht Inventor 2 12-04-2004 16:05
Inventor Help Allison K Inventor 3 23-10-2003 07:12
