Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
Unread 28-08-2006, 21:25
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
User Input
Is there a program that is similar to copycat except that it will record what the robot is doing so you can use it later instead of having to redo autonomous everytime you change the code? Thanks.
Unread 28-08-2006, 22:05
AdamHeard's Avatar
Lead Mentor
Re: User Imput
Well. I'm no good at explaining things but we wrote some software this year to do that.
If you hit a switch, it would store the pwm values for the left and right drive in two arrarys. We would then use these values as the drive code in our autonomous.
What exactly are you trying to do though, as a record function may not be the best way to solve your problem.
Unread 28-08-2006, 23:02
FRC #0935
Re: User Imput
My mentor wants to find an easier way to write an autonomous. Programmers are one thing our team always seems to lack. Expertise in programming anyway.
Unread 29-08-2006, 00:04
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: User Input
Some teams record all the commands sent to the motors on the robot during a human driven sequence, then save this data to the EEPROM memory in the processor and "play it back" as an autonomous mode.
Unfortunately our team is not one of them so I don't know how to do it. Since you asked nicely though I'm sure there's some team on here that has the program/steps to do this.
Unread 29-08-2006, 00:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: User Input
If you're going to go through the trouble to do that, you might as well also include some sensors like pots and encoders so you have repeatability that isn't dependent on voltage, binding in the drivetrain, etc.
User input via serial port AJBelayer FIRST Tech Challenge 2 14-12-2005 18:54
User Groups Brandon Martus CD Forum Support 10 08-03-2004 15:31
Autonomous user-input loophole? Jeff McCune Programming 20 14-02-2003 22:44
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
User Titles Brandon Martus CD Forum Support 27 04-06-2001 22:23
