Go to Post Andy, you have daughters, would you buy them a Dave doll? - MissInformation [more]
Go Back   Chief Delphi > Other > Dean Kamen's Inventions
  #61   Spotlight this post!
Unread 29-08-2006, 10:35
Re: Segways banned in Britain
Originally Posted by KenWittlief
The concern expressed in this thread over using the Segway as a transport system for the disabled is what happens when something goes wrong - either the rider does something the segway was not designed to handle, or the segway malfunctions (for example, the battery goes open circuit while you are riding at 12mph?).
If you're going to base your worries on operator stupidity (e.g. running into a wall) or improbable mechanical failures, there is no way to satisfy you.
  #62   Spotlight this post!
Unread 29-08-2006, 11:22
well, yeah there is: Ibot (which is how this side thread all got started)
it may sound simplistic, but engineers design systems with specific requirements, and specific usage in mind. The Ibot was designed so that you dont have to jump off it when something go wrong.
The Segway was designed for people with normal (average) physical abilities.
  #63   Spotlight this post!
Unread 29-08-2006, 15:52
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Yes, very true system usage can be expanded on through the most elaborate rules developed in HCI over the years in the case of the Segway. However, in who's eyes is the determining factor who is "normal" or fit enough for the Seg?
On a first glance, or when I am on my Seg I may fit your stereotype of "normal". However, if you spent a day with me, you would quickly come to realize I too would fall into these engineers specified requirements.
  #64   Spotlight this post!
Unread 29-08-2006, 15:56
the engineers who designed it should of had some input into the users manual. That two page speel that is in every users manual now-adays: not intended for: children, animals, persons over 250 lbs... do not use in the water or near cliffs.....
the users manual should spell out who the system was designed for.
  #65   Spotlight this post!
Unread 29-08-2006, 16:11
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Link to the user's manual. As Ken says, there are warnings in several places. See p. 8 for warnings about operating limits including weight. Specified payload weight range (per Table 2 on p. 5) is at least 100 lb. and not to exceed 260 lb.
Richard Wallace
since 2003
  #66   Spotlight this post!
Unread 31-08-2006, 11:06
Rookie Year: 1995
However, who determines what an "able bodied" individual is, compared to a "non-able bodied" individual. I don't think any engineer would ever be capable of doing that.
As a Segway owner, I was well aware of the owner manual and the user restrictions. I sure would like to know what weighing under 100 lbs. has to do with the operations of the machine though, as I've never seen it affect its "sensitivity" of the sensors.
  #67   Spotlight this post!
Unread 31-08-2006, 11:21
OK, that is a good example of a design criteria that the engineers would know about, but you may never encounter in your lifetime using the machine.
The device requires the rider be able to shift their weight fore and aft to control the speed. Based on the physics involved (the weight of the machine with its full rated payload, speed, hills, surface friction, battery charge, temp (affects motor and battery performance)) a person under 100 lbs may not be able to lean back far enough to make a segway stop under worse case situations (ie, going down a 30° incline? with 50 lb of books in a carrying case, with a 50mph tailwind....)
The engineers must design a system for the worst case scenario, and spell out limitations in the users manual. Most people dont think of things this way - that is why automobiles started being mass produced in the early 1900's but a simple thing like seatbelts were not required until the mid 1960's. No one wants to consider what happens in the worst case.
Tens of thousands of people died, who could have been saved if they wore seatbelts from the early 1900's, until just recently when most states passed laws requiring they be worn. Tens of thousands died from the 60s to the 90s, sitting on their seat belts. Why? because its human nature to reject bitter reality and to think "that doenst apply to me, thats for someone else".
I suppose Segway could create a user manual table that lists height, weight, payload limits, top speed, steepness of hills, windspeed, stopping distance.... and let people choose to ride if they stay within the correct part of a six dimensional graph, for example, if they only weigh 70 lbs but will never carry anything with them on the segway, or will never go up or down hills... but that would become so confusing it would be worthless.
  #68   Spotlight this post!
Unread 15-09-2006, 13:26
KcTechTeacher's Avatar
KcTechTeacher KcTechTeacher is offline
FRC #1847 (Bulldogs)
KcTechTeacher is an unknown quantity at this point
All Segways have been recalled because of a software design glitch. Ouch...
http://abcnews.go.com/Technology/ZDM/story?id=2434927
  #69   Spotlight this post!
Unread 17-09-2006, 07:12
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Question Re: Segways banned in Britain
I had the chance of riding the segway briefly in 2003 @ the NYC Regionals and I must say as a person who likes technology but gets scared of things running themselves (practically anyway). I in my own opinion believe that the Segway is safe. If the segway can stand up by itself w/o no help or anything to lean on for it to remain standing then it is safe by me. It's very easy to handle and operate. By GB banning this cool invention is upsetting. I just can't come up with a legitimate reason to ban something that was designed for safety all around.
As far as the Horizontally challenged people using the segway - well I'll stay neutral b/c there is too many Pros and Cons to it. What I will say is whatever can help them get from point A to point B efficiently is fine by me.
As far as the Recall is concerned eh. Nobody is perfect; espicially programmers. I don't mind the little stuff breaking, its when the much bigger stuff breaks that gets me worried and questions the company in which the product comes from.
Once again I see the segway as a much safer alternative when it comes to driving to work or riding a bike during some leisure time. I hope to own one pretty soon.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
  #70   Spotlight this post!
Unread 18-09-2006, 11:52
JVGazeley JVGazeley is offline
Don't Walk... Do the Robot
AKA: Jason Clift-Jones
FRC #0759 (Systemetric)
JVGazeley is a jewel in the roughJVGazeley is a jewel in the roughJVGazeley is a jewel in the rough
Send a message via AIM to JVGazeley Send a message via Yahoo to JVGazeley
That'd be why the only Segways I've seen have been photos and 1 at the NYC Regional then...
FRC: Team 759 Systemetric; Team Scrutineer '05 & '06, Safety Captain '06.
FLL: Cambridge (UK) Regional Helper '04 & '05, Bottisham Barnacles; Mentor '05
  #71   Spotlight this post!
Unread 06-12-2007, 19:03
krieger krieger is offline
FRC #1995
krieger is an unknown quantity at this point
think a little bit outside the box here, it probably not the apparent "danger" from a segway but the money they get- you pay a congestion charge to sit in ken livingston's traffic jams every day (8 pounds i believe) and the taxes from the gas you use. while they do waive the congestion charge for hybrids- they still use gas and the cars are so overpriced anyways that the taxes from them cover it. anyone who reads this should look up the peel p50: 106mpg from a 49cc moped engine, it has to pay congestion charge while a lexus hybrid suv at ~30mpg doesnt.
  #72   Spotlight this post!
Unread 06-12-2007, 21:44
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
On this topic, I found out the hard way a couple of months ago that Segway use is banned on streets and sidewalks in the province of Ontario.
I was gliding home from work one afternoon (a 2.3 km trip) when a squad car pulled across three lanes of traffic and stopped next to me on the wrong side of the road, and the police officer inside asked me to stop and dismount my Segway. After spending ten minutes on the radio confirming things with her dispatcher, she informed me that it is illegal to ride a Segway on public property in Ontario, unless you have a disability, or are an on-duty police officer or postal delivery worker participating in a particular study. The officer let me go with a warning, but said that if I was stopped again my Segway would be impounded and I would be subject to a fine ranging from $250 to $2500!
So since then I've been polluting the environment and contributing to traffic by taking my car to work (or sometimes I just walk, if time and the weather permit).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
  #73   Spotlight this post!
Unread 13-01-2008, 21:33
Grogs's Avatar
Grogs Grogs is offline
Builder/Engineer
AKA: Sean
FRC #1626 (Falcon Robotics)
Grogs is an unknown quantity at this point
Send a message via AIM to Grogs
finally someone with half a brain, segways are nothing but a dangerous nuisance
1626 Builder
Why did bill wear red
New Jersey Devils
LETS GO DEVILS!
Lax It Up!
http://www.falconrobotics1626.blogspot.com
  #74   Spotlight this post!
Unread 13-01-2008, 21:49
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
youre right, this was coming to them but i find this an outrage!!!
Segways Recalled Jon K. Dean Kamen's Inventions 20 29-09-2003 16:34
San Fransisco banned it DanL Dean Kamen's Inventions 13 01-03-2003 13:37
Segway Banned!! Alex Forest Dean Kamen's Inventions 10 05-12-2002 20:57
2nd Ammendment Rights: Should Guns Be Banned? Joe Matt Chit-Chat 80 03-11-2002 14:08
Casters should be banned! archiver 2001 10 24-06-2002 02:42
