Go to Post Yeah, that's a hardware problem. Definitely something to blame the electricals for. Programmers just work there. - EricH [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 30-08-2006, 23:53
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Where Could I Purchase #35 Chain?
Why online? You'll be able to suggest that you're from a FIRST team and deserve a discount, if you speak to them by phone, or better, in person. (It works.)
Canadian Bearings (They have lots of stock.)
Motion Industries
Ontario Belting and Power Transmission (These guys also have a Scarborough location.)
And places like Brafasco or Fastenal might also sell it. Call ahead to confirm stock. McMaster-Carr, SDP/SI also sell it, but you'll pay a premium, both because they don't specialize in it, and because it's shipped from the U.S..
Unread 31-08-2006, 00:00
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
best quality chain is form mcmaster-carr we have used it and have never had a problem with it, no breaks or snags
Championship - Delphi "Driving Tomorrows Technology"
Unread 31-08-2006, 01:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by Gear
while on this thread anyone know where to get #25 aluminum sprockets?
WM Berg has .250 pitch (#25) sprockets in 2024 Aluminum from 9 to 54 teeth in standard tooth counts. They all have a 1/2" diameter hub and a 1/4" bore. The part number is 25EM26A-X where X is the tooth count. They are a little more expensive than steel sprockets but they're really not too bad. They don't appear to be well stocked though. On some tooth counts there is a lead time of like 2 weeks.
Unread 31-08-2006, 01:16
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
#35 chain - Northern Tool $10/box of 10 feet w/ one master link: http://www.northerntool.com/webapp/w...9474_200139474
#35 chain - Surplus Center $13/box of 10 feet w/ one master link: http://www.surpluscenter.com/item.as...ame=powerTrans
#35 chain - Surplus Center various other types (double, stainless, etc.): http://www.surpluscenter.com/sort.as...k eyword=PC35
#35 links - Surplus Center ($.35 master links, etc.): http://www.surpluscenter.com/sort.as...k eyword=PL35
Surplus Center also has sprockets and other stuff cheaper than McMaster-Carr and MSC.
I have used the chain and links from Northern Tool and Surplus Center and it works fine. No failures at all. It is not Browning but doesn't cost as much either.
BTW: Nothern Tool is also a good place for wheels and sprockets. Look around in their Go-Cart parts section.
Also, don't forget a chain breaker like this: http://www.surpluscenter.com/item.as...i tem=14-1037
It is an invaluable "special tool" for any FIRST tool box!
Unread 31-08-2006, 01:22
Originally Posted by DeepWaterAlso, don't forget a chain breaker like this: [url
http://www.surpluscenter.com/item.asp?UID=2006083100045742&catname=powerTrans&i tem=14-1037[/url]
Cheaper at Northern Tool
Unread 31-08-2006, 01:28
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Has anyone found a chain breaker similar to this specifically for 25 chain?
I find that ours often ends up bending the link instead of pushing the pin out, due to the anvil being too large.
2001-2004: Team 100
2006-Present: Team 254
Unread 31-08-2006, 01:33
Originally Posted by sanddrag
Yep, I think I bought a chain breaker and 4 or 5 boxes of chain at Northern Tool last year and about 100 master links from Surplus Center all for less than $100 which should last a while.
Unread 31-08-2006, 01:34
Nope, I've looked and never found one either. If you find one let us all know!
Where to purchase internal gears? sanddrag Technical Discussion 3 27-02-2005 05:22
Where can i purchase a Gyro? Fishdude404 Electrical 6 15-02-2005 16:18
Where to Purchase Current Sensor KIT?? R2K2D2 Electrical 11 11-02-2004 09:58
where to purchase extra pots? Jim S Electrical 4 19-02-2003 16:17
Where to purchase spare batteries? Patrick Wang Technical Discussion 5 17-01-2003 22:10
