Go to Post There's a fine line between idolizing someone and stalking! - Jay H 237 [more]
Go Back   Chief Delphi > Other > VEX
Unread 03-09-2006, 14:56
thevexkid thevexkid is offline
thevexkid is on a distinguished road
Programming Help For The Noob
Hi peoples,
ok i have worked some with nqc (not quite C) and i hated it.
so when i heard that the defualt coding for vex is easyC i did not like it.
so if there is an alternant grafical program i can use or if someone has made a application that writs out the coding for you plese put a link or somthing here for the programing noob.
Unread 03-09-2006, 15:00
thegathering's Avatar
thegathering thegathering is offline
Angry Troll Lurking in the MUD
AKA: Ben
FRC #1885 (Robocats)
thegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to behold
Send a message via AIM to thegathering
Re: Programming Help For The Noob
Have you tried C? You might find that it's not that difficult to use.
*2006 Champion Rookie All Star Award.
*2 x 2006 Regional Rookie All Star Awards.
Unread 03-09-2006, 17:54
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Originally Posted by thevexkid
Hi peoples,
If you're looking for something with a graphical interface like easyC, you could try CoreChartFR. There's a 30 day trial version, however the full licensed version is $99.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 03-09-2006, 19:47
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Just as a reminder, that's a wrapper around assembly. I've also heard about some serious instability issues.
easyC is very good. I used it for Vex, and it's one of the better things around. Very stable. Well implemented.
If you don't like easyC and NQC, you'r basically stuck. It's either text or graphics.
Unread 03-09-2006, 20:42
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Hi peoples,
The Vex platfrom essentially uses only C programming in one form or another. You have two choices. Either A.) use easyC or B.) use MPLAB and write your code out manualy in the IFI default code. If you have a particular problem with the C programming language, then you are stuck unfortunatly. However, don't toss away easyC without using it. It is a very powerful tool that I know anyone can use. I personally trained a fifth grader to use easyC within two hours, and I also worked with a group of 7-8th graders at a Vex camp who were all also able to learn how to program.
Perhaps if you gave more information as to why you dislike NQC or easyC, we may be able to help you more.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 04-09-2006, 01:09
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I assume from the above statement that you have not yet tried EasyC; rather that you heard it was called "EasyC" and assumed that it's similar to NQC or traditional C programming. While NQC and EasyC both utilize similar syntaxes, EasyC uses a graphical user interface (GUI) with drag-and-drop command blocks.
That's exactly what EasyC is: a graphical programming application that creates all the C code for you.
Art Dutra IV
世上无难事,只怕有心人.
Unread 04-09-2006, 10:45
AKA: Ben
I think he knows that, hence why he said "alternate graphical program" instead of "a graphical program".
I think what he's saying is, he doesn't like the EasyC interface and he's looking for something different or a similiar program.
I've checked through the GNU libraries with no results. It seems as if it's either EasyC, NQC, some booger party software, or you're on your own with the C language (which is what I prefer to use anyways).
Unread 04-09-2006, 17:47
Question Re: Programming Help For The Noob
Hmmmmm.
Iv'e bean working on a program that writes out the code for nqc for some time.
btw. i thought that nqc was for lego mindstorms ???
Unread 04-09-2006, 18:27
AKA: Ben
They suggest it be used that way on their site, but it can be used to generate real C code.
Quick Q for "noob" at first V8GTORacer General Forum 19 30-01-2014 21:43
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
What is the first step for programming? sjung9442 Programming 6 22-01-2006 21:54
Karel++ Noob help henryBsick Programming 4 08-09-2005 16:03
Please Help: Programming the Robovation Kit wmurphy Robotics Education and Curriculum 14 08-12-2004 12:57
