Go to Post Keep 'em cool, run it fast! - ChrisH [more]
Unread 04-09-2006, 14:54
Aren_Hill's Avatar
Build Nifty Things
Miter gears
Anyone have suggestions for what type of miter gear setup will handle the power of a cim through a dewalt? i'm designing a drivetrain and i need some but i don't know what i need. A Mcmaster Carr # would be useful.
Thanks
Aren Hill
A guy who likes robots.
Unread 04-09-2006, 19:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Miter gears
You need to give us an example of the output speed, so that we can estimate the torque on the gear (rotational speed × torque = power). Also, what limits the torque on the gearbox (most robots reach an upper limit when their wheels slip, but if there's a braking mechanism, it must be considered)?
As an estimate, look at something like this from SDP/SI. If you mount it rigidly enough, it should withstand typical use in any of the three gears, assuming the DeWalt and CIM are configured per the NBD whitepaper.
Unread 04-09-2006, 20:04
Aren_Hill's Avatar
Build Nifty Things
Re: Miter gears
the out put is the 12-1 4-1 and 3-1 of the cim motor and i want the gears to be able to accept full stall power and not break. i will be using dewalts in the NBD whitepaper one on each wheel.
gears Michael Leicht Inventor 12 16-09-2004 10:52
Gears Jack 3D Animation and Competition 7 08-07-2003 21:39
Gears Thunder360 Technical Discussion 10 23-03-2003 11:33
gears....? archiver 2000 16 23-06-2002 22:58
