Re: Conifirming somthing
I'm new at this too, but here's what I think you are looking for. Please feel free to ask for further clarifications.
I'm assuming that you are referring to the cables that get hooked up to the VEX controller. Most of the cables are Red, Black and White. The red wire has +5 volts, the black is signal return and the white is data. The data cable can either provide a digital output (on/off) of +5v or the motor outputs can provide a PWM output. These PWM outputs make a 1-2 millisecond (ms) pulse every 18.5 ms. A buzzer may work well because you can just turn it on or off. The digital signals are good at that. I would recommend that you check the current draw of the buzzer before you hook it up though. I haven't checked the specs on the VEX kit yet, but most microcontrollers are only capable of 25mA. If it takes more than that I'd recommend that you use a relay or transistor to switch it on and off and use something else to power it, like batteries. You will have a lot of trouble hooking up a standard speaker directly to one of the ports for 2 reasons. First, the processor isn't fast enough to make anything more than a simple tone. Second the you might draw too much current and damage the VEX controller. A speaker has a coil of wire so it may behave like an inductive load. Inductive loads have the ability to create power spikes significantly higher than you would expect. As I mentioned earlier, I haven't checked the manual yet. My numbers may be off. Hopefully I've got you pointed in the right direction. Andy |
The black wire is generally called "ground".
There is no explicit negative current. A piezo may be suited for this kind of application. But I'm not an electrical person, do your own digging. |
It's true that the black wire is often called ground. It's a frequent mistake. Technically ground is into the earth. Most mobile robots don't have an electrical connection to the earth.
Anyhow there are lots of terms for it. Common and signal return are both accurate. People will usually understand ground and get the right idea, but the term is not really accurate for this application. Andy |
Ok lots of help (not sarcastic) thanks a whole lot will post a pic of my setup with the buzzer when it is finished.
im a noob to vex but am an electrical genious so this is great! Whoa whight is DATA!! never would have guessed that!but again thanks a whole ton guyes. ![]() |
| pic: Somthing missing? | CD47-Bot | Robot Showcase | 21 | 28-10-2003 20:42 |
| Need a little help on somthing | 157#1Driver | General Forum | 4 | 03-12-2002 22:07 |
| Question on posting somthing | archiver | 2000 | 0 | 24-06-2002 00:24 |
| hint or am i forgeting somthing.. | archiver | 2001 | 5 | 23-06-2002 22:06 |
