Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Go Back   Chief Delphi > Other > VEX
Unread 05-09-2006, 18:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Conifirming somthing
The black wire is generally called "ground".
There is no explicit negative current.
A piezo may be suited for this kind of application. But I'm not an electrical person, do your own digging.
Unread 06-09-2006, 01:06
Culvan Van Li's Avatar
Culvan Van Li Culvan Van Li is offline
Jack-Of-All-Trades
AKA: Andy
FRC #1939 (Kuh-Nig-Its)
Culvan Van Li is on a distinguished road
It's true that the black wire is often called ground. It's a frequent mistake. Technically ground is into the earth. Most mobile robots don't have an electrical connection to the earth.
Anyhow there are lots of terms for it. Common and signal return are both accurate. People will usually understand ground and get the right idea, but the term is not really accurate for this application.
Andy
Unread 06-09-2006, 08:33
thevexkid thevexkid is offline
thevexkid is on a distinguished road
Ok lots of help (not sarcastic) thanks a whole lot will post a pic of my setup with the buzzer when it is finished.
im a noob to vex but am an electrical genious so this is great!
Whoa whight is DATA!! never would have guessed that!
but again thanks a whole ton guyes.
pic: Somthing missing? CD47-Bot Robot Showcase 21 28-10-2003 20:42
Need a little help on somthing 157#1Driver General Forum 4 03-12-2002 22:07
Question on posting somthing archiver 2000 0 24-06-2002 00:24
hint or am i forgeting somthing.. archiver 2001 5 23-06-2002 22:06
