Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 05-09-2006, 22:41
Floydlax Floydlax is offline
Floydlax is an unknown quantity at this point
Need help factoring a 3rd Degree polynomial
having trouble factoring the following problem
x^3-10x+3
I have done many like this before but misplaced my notes and ahve no way of familiarizing myself with the processes needed in order to factor this.
Can anyone help me...
much appreciated thanks
Unread 05-09-2006, 22:59
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Need help factoring a 3rd Degree polynomial
Use the factor theorem: for a polynominal f, if f(a) = 0 --> (x-a) is a factor
In this case, f: x^3 - 10x + 3
f(3) = 3^3 - 10(3) + 3 = 27 - 30 + 3 = 0
Therefore, (x-3) is a factor of f.
Using synthetic division (I'll leave this step to you), you can see that f = (x-3)(x^2 + 3x - 1)
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 06-09-2006, 02:39
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
I used to know a trick to solve cubic polynomials, but that has long since escaped me.
Here's a pretty complex formula that will give you your roots directly.
You can also take a brute force approach that you can use is the Rational Root Theorem. Essentiallty what it says is that for any polynomial, each rational root will have the property that x = p/q wher q is a factor of your x^0 term and q is a factor of your x^n term.
In your case, it's pretty easy.
p has to be +-1 or +-3 and q has to be +=1
So all combinations will give you the following values of x. Once you have those, you plug them into your original equation and find the ones that make the roots.
x = 1 ==> f(1) = 1 - 10 + 3 => -6
x = -1 ==> f(-1) = -1 + 10 + 3 => 12
x = 3 ==> f(3) = 27 - 30 + 3 => 0 <-- Rational root
x = -3 ==> f(-3) = -27 + 30 + 3 => 6
So as Karthik pointed out, since 3 is a root, (x - 3) is a factor. From there you should follow his other suggestion of using synthetic division.
I also came across this page which has some pretty good examples. In particular, you may want to take note of the Intermediate Value Theorem. They also talk about synthetic division if you need a refresher.
Need assistance for a -40 degree cold chamber Don Wright General Forum 13 24-06-2005 20:00
Factoring 3rd degree polynomial sanddrag Math and Science 5 02-02-2005 00:10
Whats your hardest factoring problem? jon virgi Math and Science 1 19-04-2003 01:28
