Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 06-09-2006, 02:39
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Need help factoring a 3rd Degree polynomial
I used to know a trick to solve cubic polynomials, but that has long since escaped me.
Here's a pretty complex formula that will give you your roots directly.
You can also take a brute force approach that you can use is the Rational Root Theorem. Essentiallty what it says is that for any polynomial, each rational root will have the property that x = p/q wher q is a factor of your x^0 term and q is a factor of your x^n term.
In your case, it's pretty easy.
p has to be +-1 or +-3 and q has to be +=1
So all combinations will give you the following values of x. Once you have those, you plug them into your original equation and find the ones that make the roots.
x = 1 ==> f(1) = 1 - 10 + 3 => -6
x = -1 ==> f(-1) = -1 + 10 + 3 => 12
x = 3 ==> f(3) = 27 - 30 + 3 => 0 <-- Rational root
x = -3 ==> f(-3) = -27 + 30 + 3 => 6
So as Karthik pointed out, since 3 is a root, (x - 3) is a factor. From there you should follow his other suggestion of using synthetic division.
I also came across this page which has some pretty good examples. In particular, you may want to take note of the Intermediate Value Theorem. They also talk about synthetic division if you need a refresher.
Need assistance for a -40 degree cold chamber Don Wright General Forum 13 24-06-2005 20:00
Factoring 3rd degree polynomial sanddrag Math and Science 5 02-02-2005 00:10
Whats your hardest factoring problem? jon virgi Math and Science 1 19-04-2003 01:28
