Go to Post Being a mentor only requires an open mind and fifty thousand times more responsibility. - Amanda Morrison [more]
Unread 06-09-2006, 17:21
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Number reassignement for 06-07
Hello everyone I spoke with my teacher and robotics team mentor and he said our vex number was changed from 68 to 3036 I highly doubt that their are that many teams so i don't know the reason
-Dustin Benedict
Unread 06-09-2006, 17:23
Billfred's Avatar
Billfred Billfred is online now
Re: Number reassignement for 06-07
When all else fails, check the FAQs:
http://www.innovationfirst.com/fvc/faqs.shtml
Originally Posted by the link
Team Number Changes
Q. Can I get my Vex team number the same as my FRC team number?
A. Yes, but not during the registration process. Just complete the registration process and you will be given the next available number (numbering started at 3000). After you have completed the registration, just send us an email, (Info@VexRobotics.com) requesting a team number change and reference both team numbers. After verification we will issue a team number change. You can only do this change if you already have a previous years FRC team number. Example: If your previous years FRC team number is 148, your vex team number can be 148.
Q. Can I get my Vex team number the same as my previous Vex team number?
A. No. You can get a team number in the 2000s though but not during the registration process. Just complete the registration process and you will be given the next available number (numbering started at 3000). After you have completed the registration, just send us an email, (Info@VexRobotics.com) requesting a team number change and reference both team numbers. After verification we will issue a team number change. You can only do this change if you already have a previous years Vex team number. Example: If your previous years Vex team number is 148, your Vex team number can be 2148. Your Vex team number can not be 148 because 148 is reserved for the FRC team 148. A team number in the 2000s will signify your team was a part of the initial FIRST Vex Challenge.
Unread 06-09-2006, 19:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
There isn't an FRC 18 atm, so I hope they let us chose FVC 18 again...
We've grown attached...
Unread 06-09-2006, 19:25
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
This is a bit confusing.
If they're assigning Vex teams numbers like 2148 because they're trying to avoid confusion with FRC teams, what numbering scheme are they going to use for rookie FRC teams? Aren't we at about the time when the FRC numbering ought to begin at 2000?
--Madison--
...down at the Ozdust!
Unread 06-09-2006, 19:37
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
team 2000 will be born this year as well as 2100 and maybe 2200, but this change in numbers is confusing, ive had VEX team numbers memorized...now im just lost.
Blargha!
Unread 06-09-2006, 20:24
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
I might be wrong, but I thought the two-thousand series would indicate that you were a Vex team from season two (2005-2006); the three-thousand series is being assigned to rookie FVC teams because this is technically the third season. And they are offering the option of having the same number as your FRC team because teams asked for it last year. But that's just speculation on my part. And once we hit 1000 FVC teams, the numbering scheme falls apart anyway! (Let's aim for that THIS year!)
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 06-09-2006, 20:26
Madison's Avatar
FRC #0488 (Xbot)
Yes, that's correct -- it's just that the reasoning presented, that FVC 148 may be confused with FRC 148 and thus will be assigned as FVC 2148 doesn't make too much sense when there's a pretty good chance there will be an FRC 2148 this season.
--Madison--
Unread 06-09-2006, 20:45
Billfred's Avatar
I don't know if it's so much confusion as folks wanting to keep their numbers the same. I can think of two FVC teams in Atlanta that were switched to their FRC numbers, 935 and 148 (who, as there already was an FVC 148, were dubbed 1148). I can only imagine that there were others over the season that either wanted it or asked about it who didn't come to Atlanta.
Personally, I don't care one way or the other, but I hope that these numbers stick.
Unread 06-09-2006, 20:47
Madison's Avatar
FRC #0488 (Xbot)
Okay, so I'm the only one who's confused, then I can accept that.
This is what I get for paying no attention to Vex at all.
--Madison--
Unread 07-09-2006, 00:33
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Yes there were multiple teams to do this Billfred. I know FVC 173 had opened up for some reason, so FRC 173 requested a number shift to FVC 173 from some other FVC number(of which I don't remember)
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 07-09-2006, 09:02
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
I just received a change to our FVC team number this year. So instead of being 3031, we're now (2 or 3)228. Keeping the numbers the same will help a lot.
Last year at the Hartford FVC event, our team's registration payment was credited to FVC team 228 because it was paid with a check from our FRC 228 team's account.
Luckily, it was cleared up a few days before the tournament.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 07-09-2006, 11:30
Billfred's Avatar
Wouldn't it just be FVC 228, since that's an FRC number?
Unread 07-09-2006, 18:36
thefro526's Avatar
Mentor for Hire.
Thanks everyone it still kinda stinks though cause now we're gonna have to design new shirts. The General assuption is that my team number will be changed to 2816
-Dustin Benedict
Unread 07-09-2006, 19:51
Billfred's Avatar
Not quite. Since your FRC number is 816, your FVC number will be 816. 2816 would be reserved for the team known as FVC 816 last season, assuming that team didn't have an FRC affiliation.
Unread 07-09-2006, 21:33
thefro526's Avatar
Mentor for Hire.
Thank you for clarifing that issue After rereading the rules I understood exactly.
-Dustin Benedict
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Number 2 srjjs General Forum 15 24-01-2003 08:27
Part Number for Left Hand Screw archiver 2001 2 23-06-2002 23:35
number of Regionals purplehaze357 Regional Competitions 10 17-04-2002 22:25
3 is the number and the number shall be 3... Joe Johnson General Forum 21 03-12-2001 17:08
