Go to Post What makes a team great is not what they do during the 6 weeks, but what they do the rest of the year. - davidthefat [more]
Unread 12-04-2006, 20:40
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: pic: Omnitrack Summer Project?
Why not CNC punch them out? I am fairly certain that you can
punch 1/4 aluminum, and it would be alot more consistant/pretty.
Also... Why omnitracks? Won't a 4-6 wheel omnidrive perform just as well as a two track two wheel design?
Unread 12-04-2006, 21:46
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Extrusion requires a difficult setup and expensive tooling; it's only cheap in huge volumes. But what about graphite permanent mould casting? If you can get a local casting shop to sponsor you, it wouldn't take much to make a few hundred links.
Basically, you'd need to mill out the mould into two graphite halves with sprues, vents and risers as necessary (usually CNC—a casting shop will be able to do this easily), and it's just a matter of mounting it to a standard fixture (which opens and closes the halves) before you're ready to pour metal (e.g. 390 aluminum).
Unread 12-04-2006, 22:34
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
So, assuming you are going with a standard tank setup, whats to stop someone from going on the side of you, and pushing you straight across the field?
Doesn't look like it would offer much resistance to that.
Unread 12-04-2006, 22:48
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
He explained it in his first post. If you can imagine, there are four treads, at each edge of the robot. So if someone pushes you from the side, the front/back treads should resist somewhat, in theory the system, if made, should be better at torque that the OMNI wheel drives.
Just a suggestion, instead of having 4 treads, why not have 2 treads on each side, and one in the middle(which intersects the turning center). This way if you need to implement the drive on a robot that herds or uses its back or front for other things, you will be able to fairly easily use the same concept. On a side note, this will make the robot more vulnerable to pushing.*Just a random thought*
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 12-04-2006, 23:00
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
I think that Andy brought up a good point about using standard chain attachments with links mounted to them. I have been thinking about doing this for a little while, but haven't found the time. Maybe you can puts this to good use before I can.
Connecting links with mounting flanges can be found at McMaster on the last page of roller chain.
If you can get something similar to the part shown in the attached pic stamped out of plate to hold the rollers, I think that it will work when mounted to the chain. By properly sizing these parts, you may be able to make the chain lock in one direction giving the omnitrack rigidity between support rollers, but the ability to collapse around drive sprockets.
This is of course just concept, and needs tweaking.
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
Unread 12-04-2006, 23:53
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
Originally Posted by Greg Perkins
I assume you mean Omni wheels. And no, this won't behave like tank treads, it's a whole different animal. You've got to take into account being pushed, your coefficient of friction, and the need of the design. Is it doable, yes...is it practical, don't know. Do some research, and let us all know please!
No, i think i know what I'm saying as confusing as it may be, let me explain then feel free to correct away(i might want to pursue this idea of mine). It has already been established that this system is going to be implemented in four different treads each at a corner of the robot, my idea is to instead of having the rollers 90deg from the direction of the tread moving as shown in the picture, have them set at either a 45deg or 30deg and leave the treads parallel to the other side. My reasoning for believing that this may work is that if you imagine traditional tank treads as just an elongated and spoke-less wheel that travels in an ellipse to move its load instead of a circle, setting the rollers this way will function as nothing more than this perception applied toThese Mechanum wheels on the first page, with all the drive and other characteristics of the wheels applying to them. If this however is too confusing because my mind works in strange ways the treads will be positioned like
l l
l l
and the rollers positioned like
just an idea and ill try to make a more detailed drawing to clarify what i mean when i get time
-Simon
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 13-04-2006, 00:23
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I thought of omnidirectional treads too when trying to think of an interesting drive system and it's nice to see that someone else is persuing the idea.
One problem I thought of though is this:
If you have 1 tread on each side of the robot, then each tread will only receive about 25% of the total weight of the robot. When you try to push someone forward, you will only be using two of the treads. Since only 50% of your robot weight is on those treads, then you have a significantly reduced pushing power (less traction than a typical 4 wheel robot), even though you are using treads.
Then I remembered "Oh wait, omni treads would be sweet!" and it cancelled out the previous thought.
Unread 13-04-2006, 02:29
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
True enough, and I have given much thought to different drive configurations.................................... ......................................... My favorite (4 treads):....Another idea (3 treads):...........Killough (3 treads):
Realistically, these will take time and money to make, so I am thinking about this for a test platform (2 treads, 2 omniwheels working in tandem):
To have the best performance on the field, you would have each tread independently controlled. Just to throw another idea onto the field, what if you used four DeWalt 3-speed shifters with FP motors, and had a 3-speed omnitrack robot? That would be incredible.
Why consider omnitreads at all? Two words: Freaky Mobility.
I am having problems attaching images. Periods represent blank spaces. Sorry.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 19-04-2006, 22:54
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
With all honesty, this is cool, but it makes no sense to me.
You should put the wheels in a diamond pattern, so when you're pushing forward, you're at around 75 not 50% efficiency.
But what makes no sense, is why you want treads.
For non-deforming surfaces, frictional force is independent of area. IIRC, Tank treads make sense in that they can "dig in" and create normal force (instead of frictional force) but these AM rollers dont deform, dont dig in, dont really do anything but add weight. since there's only two points where the weight is supported (the aluminum sprockets) this is functionally equivalent to having two omnis on each side of the square.
Also, why are you filing? you have access to a SWEET cnc mill, it'd only require a fraction of the machining you did for your wheels
Tatsu out.
Unread 20-04-2006, 10:43
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Uhm...If the rollers are at 45 degree angles to the tread, then the tread should be mounted parallel to the frame at the four corners; the nature of mecanum systems is such that you receive standard weight distro, speed, and forward traction, while gaining the manuverability of omniwheel systems.
Good luck.
www.metalmoose.com
Unread 20-04-2006, 11:04
I dont the the OP is talking about 45 deg rollers, and if OP did do that, he'd need the treads set up like traditional mecanum wheels (ie two treads / side) rather than the square shape he has now.
Unread 06-09-2006, 21:10
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
im just wondering how the work on this idea has been going along, because a couple of members on 1712 along with myself are working on a omni tread design as well. just wondering how far its gotten. and i think i figured a way to keep the treads in a straight line and have a good sprocket for them to move on.
Unread 07-09-2006, 00:28
Gabe's Avatar
Not so well, because I realized that the tracks would weigh a lot if they were made of aluminum and if each had a 3/16" steel link pin. Also (heh) I noticed that with my design it is physically impossible to install the last link, and therefore it is impossible to complete one entire track. To put the 1/8" steel pin in, it would mean that it would have to go through the 3/16" pin.
If I were to change my design, I would make the links out of plastic, and have cylindrical rollers instead of barrel shaped rollers.
This will give you an idea of what I mean. Sorry about the image, but without AutoCAD, Inventor, or Solidworks, I have to work with what I have: Microsoft Word. This shows the top view of my idea, and you can see the cylindrical rollers with a pin going through (maybe 1/8"). The tread links are joined at the top and bottom by another pin ( maybe 1/8").
pic: 1541 - SARTANYAC: Beta Project bombadier337 Robot Showcase 2 22-02-2006 19:24
pic: Project X climbing up the side of the ramp CD47-Bot Robot Showcase 2 25-02-2004 23:24
SCRRF Robotics Summer Camps Redhead Jokes Southern California Regional Robotics Forum 0 24-03-2003 15:06
Preseason project AdamT General Forum 4 09-09-2002 00:52
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
