Go to Post Dean's never ending fountain of denim. - kjolana1124 [more]
Unread 07-09-2006, 09:49
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: ARC Welding Aluminum
Just some added info. TIG (Tungsten Inert Gas for those that don't know the accronym) allows the welder to better control the heat input with the torch so that they can better control the heat affected zone and minimize warping the metal.
Also I wouldn't suggest MIG (moving inert gas) welding a long seam straight through as the distortion will significant. It would be better to use a back-stich technique to minimize the thermal effects.
Thank-you 294 & 67
www.bobcatrobotics.org
Stick Welding Aluminum sanddrag Technical Discussion 2 02-02-2006 13:17
MIG Welding Aluminum sanddrag Technical Discussion 11 15-09-2005 13:50
Power arc? Tytus Gerrish Technical Discussion 1 31-08-2003 20:15
No welding? Katie Reynolds Rules/Strategy 7 20-02-2003 17:33
WELDING BOOTY BURGLAR OCCRA 2 05-10-2001 21:22
