Thread Tools |
Rating:
Display Modes |
#21
Re: USB Joystick adaptor is here!
So as I see it the question is, can FIRST ensure safety on the field while allowing externally powered devices connected to the O/I joystick ports? Maybe their answer is no. Or maybe it is yes[/quote]
The answer, I believe is yes. Of course I'm biased... Actually pulling power from the comp port should not be a saftey issue. The robot's are disabled via the mode bits. I believe, not certain, that the E-stop kills power to the O/I. With these saftey features already in place there is no reason, other than the rules, that pulling power form the comp port, would be unsafe. I agree that custom circuits should not be allowed use external power sources. |
| intelitek loader/vex USB-serial adapter driver | MrForbes | Programming | 2 | 07-04-2006 13:37 |
| USB serial adapter for OSX? | Validius | Programming | 1 | 05-01-2006 01:43 |
| USB-Serial adapter | Bill_Hancoc | Chit-Chat | 4 | 03-01-2006 07:18 |
| USB to Serial adapter | John Gutmann | Programming | 7 | 09-05-2005 01:34 |
| BAFO USB to 9 Pin Adapter | Skiguy523 | Programming | 2 | 29-01-2005 01:49 |
