Go to Post A team pulls together when things get rough. - Aignam [more]
Unread 08-09-2006, 11:22
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Article on Skin sensing table saw
The article mentions a fuse that gets burned up to spring the brake. I believe that this is what needs to be replaced. A task like that wouldn't be much different than an ordinary replacement fuse on a consumer product.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 08-09-2006, 11:34
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
If you download the user manual, it goes into great detail about replacement of the brake system.
First, you have to understand how the brake works, then you can understand why it's a bit more complicated that just replacing a fuse or resetting a spring. The brake is basically a piece of aluminum that is forced into the teeth of the blade. When the system senses a step change in the control voltage, this curved aluminum block gets rammed into the blade. The blade embeds itself into the block and is stopped in a few milliseconds. (The slo-mo video is wild to watch...)
So, what needs to get changed? The entire brake system, which looks to be one complete module. However, since the blade is being forced into the aluminum, they recommend changing out the blade as well! So, can the blade and module be changed out in 5-10 minutes? Probably. The toughest part is probably extracting the blade from the aluminum block, nothing a block of wood and a hammer can't take care of.
So, is the extra money and the time delay worth a finger? That's up to you. Would I recommend a product like this in every school system that has a woodshop? You better believe it! A trained woodworker should have the experience and the know-how to protect himself. Unfortunately, I can't say that about most students, or even myself.
BEN
Unread 08-09-2006, 11:43
BEN
Ben,
You reminded me of why I posted this originally. It immediatly made me think of your former Hydrogen Source coworker who cut off 3 fingers on his table saw (all reattached). Also the number of people around our shop who are missing part or all of a finger. To me adding the price of the device up front and replacement parts is worth it no matter how careful you think you are. If the device is retro-fittable to older saws I'll be buying one for my father, an avid wood worker, asap. Otherwise he may have to wait a little longer until we get him a new saw.
Pete
Thank-you 294 & 67
Unread 08-09-2006, 12:14
BEN
Give me an hour and I'll bet I can come up with 5 ways to design a table saw type of machine that will prevent you from pushing your fingers into the spinning blade, and none of them will involve destroying the blade or jamming blocks of alumimun into spinning machine parts.
Unread 08-09-2006, 13:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Dean Kames once said something along the lines of "Every engineering project is a solution to a problem, but not every engineering solution is something the public needs."
I believe this invention is a marvelous idea, but it just isn't practical in the real world. Once you (a company) start claiming things to be safe, all it takes is one equipment malfunction and you're really in trouble.
The problem I have with things like this is that the easier you make it for people to do something, the lesser skilled they become. I think technology like this would put power tools in the hands of people who really have no business using tools. Power tools are nto for everyone, there's no changing that fact.
I mean seriously, what are they going to do, safen every dangerous tool out there? Put a compressable sleeve over dril bits? Permanently affix a shield into a welder's head? Make an oxy-acetylene torch that you can't point at yourself?
No invention should ever replace simple diligence when it comes to using power tools.
Unread 08-09-2006, 13:48
But I don't think that argument should be used to naysay a safety feature. If a power tool can be made more benign when simple diligence is trumped by accidental circumstance, I consider it a good thing.
The point of inventions like this is to make systems more fail-safe. That means they're more safe when existing practices fail -- which they obviously do.
Unread 08-09-2006, 16:40
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
i can relate to this because i have personal experience with the said table saw. my school's shop has one and i was in the cabinet making 1 class last year. our teacher was not the least bit less concerned when we used the saw stop. usual precautions were always taken not matter what.
still, i gotta say that i somehow felt safer while using the sawstop. that quick "stop and drop" feature was like an angel over my fingers. most of the other students in my class prefered it over the old table saw we had, too. though we didn't need it, the technology and safety was more relaxing condition to work under.
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
Unread 08-09-2006, 17:22
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
We have one of these saws here at ULL, I was talking to the guy incharge of the shop today about it. He really likes it, esp since its more powerful than the last saw. He also said that sometimes the thing would trip if you put a metal ruler into the blade, no big deal though since its not spinning the aluminum wouldn't bond into the blade. He says its overall a really well made saw even barring the stopsaw part, he said it rarely ever kicks and whatever other things master cabinet makers like about saws.
He did say however he was having issues with certain blades not having the correct diamter so you have to be pickey with your choice, and as he said to us today,"if i can save you finger for the $70 it costs for the new cartrige i will pay it out of my pocket" for anyone having unexperienced (and overworked/undersleeped design students) using a table saw its the way to go.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 08-09-2006, 21:08
DonRotolo's Avatar
Back to humble
FRC #0832
I agree with some posters, that the issue here is whether to make such a device mandatory or not. I, for one, hate mandatory things (most of the time).
This is much like chain brakes that were developed for chain saws. In many models they are required, and in fcat they are a darned good thing to have. Certain high-end professional saws are exempted, but the people using them are usually quite experienced.
Would I retrofit this device onto my table saw? Probably not. Is it worth the money? Absolutely.
The bottom line is taht if it costs $25 million per year and saves just a single damned finger, it's worth it. Especially if that's MY finger there.
But, give me the choice.
Don
Unread 08-09-2006, 23:41
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
BEN
Ben as a college job i work at Home Depot, i worked in the Lumber Department, until..... anyone who has seen my left arm knows what comes after the until...
Let me tell you something, I will honestly admit, I made a mistake, i wasn't paying attention, and i put my arm in front of a spinning saw blade...
as a result, The Home Depot, fined my store, 200,000 dollars, because after the lawsuits and medical bills and what not, thats the approximate cost to the company, if an employee hurts is seriously injured on the job... never mind if a customer is hurt, and subsequently if you have been to home depot near the saws in the past year or 2, you probably have seen what the My store managers have affectionately refereed to as "The Schroeder Maneuver" on the Radial arm saw
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 17-09-2006, 21:10
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
BEN
I agree.
However, I think that pushing for legislation in order to sell your product compromises the free market economy. The best solution for this product would probably be to change it so that it can be used as a "retrofit" instead of a factory-installed-only product.
A salesman going to a school wood shop teacher with the hot dog video and a low enough price to retrofit the school saws would probably have enormous success.
It'd also be nice if the stopping solution was a bit more...innovative for lack of a better word. Destroying the blade and destroying the brake mechanism in the course of a normal deployment isn't a very good design IMO. I'm not saying that I'm prepared to present something better, I'm just saying that it shouldn't be mandatory for a table saw to eat itself. Sandrag brought up GFCI devices, which are an excellent model of an easy to reset and non self-destructive safety device. What we have now is a fuse, but we need a breaker. (To continue the electrical analogy.)
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 17-09-2006, 22:27
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
I agree with those who have said this should be available but not mandatory. I firmly believe that once customers begin realizing that there is a safer product available, they are fit to make the decision themselves whether it is worth it. I know if I were purchasing a table saw I would want this technology, but to each their own. Just don't ask me to pay for it when someone cuts their own finger off with their own table saw that doesn't have this technology included.
My school's wood shop just upgraded to a sawstop table saw, and as a new user most at risk of an accident with this thing, I applaud their choice. Of course, I'll be sure to stay on guard while operating the machine, sawstop or no sawstop, I feel better knowing that it's there in case of an accident.
Originally Posted by KenWittleif
If you take a zero-accident approach then everything has to be very expensive, time consuming to use, with double redundant safety features.
It is true that a line between safety and efficiency has to be drawn somewhere. But for me, this technology doesn't cross or even approach that line. The only thing distinguishing this saw from any other table saw is a slightly higher initial cost; it still operates like all the others - until it hits your flesh. At that point, it may have just saved your finger. And even if in so doing it destroyed the entire apparatus, I'd consider the save worth it. I'd say a $70 easily replaceable cartridge is a good bargain for a priceless, irreplaceable finger.
Again, I'm not in favor of forcing this on anyone, but I think the technology definitely has promise.
Edit: Missed spell-check.
Oh, maybe I shouldn't have pushed that...
Unread 25-09-2006, 19:49
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
just to throw in some info I found out. I know someone in the wood working industry and saw this saw at a trade show, he said it puts on an awesome demonstration, but they don't come out and tell you it costs over $200 per catridge. I think he said it was some type of a block that gets jammed into the blade to stop it from spinning.
That is great if it saved soemone's fingers, but in a high school, i could only imagine how many times it may accidently be set off (costing $200 each time). Assuming no one is dumb enough to try it with fingers, but what about a wet towel, wet wood, food, etc...
Soudn sgreat, but from what i've heard it is a bit overpriced.
And NOTHING beats proper safety practices..
~ Mr. Buonomo, Team 871
Unread 12-10-2006, 15:10
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
My company recently purchased one of these for the Carpentry Shop. They have now banned the use of non-safety table saws within the plant. The cartridge has an aluminum block shrouding the blade that is fired into the blade when activated. The torque of the motor forces the blade to withdraw into the table at the same time. This effectively ruins the blade and the cartridge needs to be replaced. Of course you can run with the safety circuit inactive, but why?
After all, what is the cost of a finger lost or having to be sewn back on? Besides the time you need it is when you least expect, most people try to work safely. This goes along with the other thread about working safely without safety glasses.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 12-10-2006, 15:19
Originally Posted by Andy Brockway
After all, what is the cost of a finger lost or having to be sewn back on? ...
good question. Is the company going to make the employee pay for the new blade and the $200 cartridge everytime they touch it and it triggers?
Seems reasonable, if you trip the sensor it was your fault, and it saved your finger, right?
BTW, does it really have a SAFE / UNSAFE switch ?
pic: 1141 gets under 379's skin CD47-Bot Extra Discussion 2 06-04-2004 09:27
AOL Instant Messenger Skin! Gadget470 General Forum 16 31-10-2002 00:03
What's Your Winamp Skin? Ryan Dognaux Chit-Chat 23 27-10-2002 15:34
Customizable Winamp3 Skin for Teams... Clark Gilbert Computer Graphics 3 07-10-2002 19:57
Who saw the FIRST article on wired.com? archiver 2001 6 24-06-2002 02:34
