Go to Post I don't care what the team numbers said, on Friday there were no rookies there. - Taylor [more]
Unread 08-09-2006, 14:56
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Martians 494 cvt pics
I was searching today for some pics of 494's cvt from 2004.......they pop up on google but the links to the website are busted.
Can anyone help me get the pics? I'd also be curious to discuss tuning and other cvt related things.
Thanks.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 08-09-2006, 15:09
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
Re: Martians 494 cvt pics
http://firstrobotics.uwaterloo.ca/gearboxesgallery.php
Scroll down about 2/3's of the way. Theres 4 or 5 good pics.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 08-09-2006, 15:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Thanks.
I just discovered today that my 1978 Peugeot 103 SP moped that I bought a little less than a week ago has a CVT type mechanism they call "the variator" The whole engine is mounted on a pivot and pushed with a spring to keep the belt tight. It is really quite mesmerizing to rev up the engine and watch the pulley slide over and essentially become larger and watch the engine shift backward to take up the slack in the belt. I have very little idea how it actually works, but it is quite fascinating.
Here is the owner's manual: http://www.mopedriders.org/html/manu...nersmanual.pdf
And here is the service manual: http://mopedriders.org/article_view....q=2&fldAuto=36
Unread 08-09-2006, 22:22
JackN JackN is offline
AKA: Jack Nowakowski
JackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond repute
These are the pics of it that were on 1114's database for those who don't want to scroll.
http://firstrobotics.uwaterloo.ca/re...earboxes76.jpg
http://firstrobotics.uwaterloo.ca/re...earboxes78.jpg
http://firstrobotics.uwaterloo.ca/re...earboxes79.jpg
http://firstrobotics.uwaterloo.ca/re...earboxes80.jpg
http://firstrobotics.uwaterloo.ca/re...earboxes81.jpg
http://firstrobotics.uwaterloo.ca/re...earboxes82.jpg
http://firstrobotics.uwaterloo.ca/re...earboxes83.jpg
Our website is being rebuilt and the pictures haven't been moved yet.
Thanks for such a great program 1114.
2005-2007 Team 494 (Lead Scout and Strategist)
2008 Team 70 (Drive Coach)
2009-2011 Team 1504 (College Mentor)
Unread 08-09-2006, 22:47
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
What are the points of the brass fin-thingies? I remember seeing it at IRI in 2004, and having the full system explained to me, but I can't recall what the brass fins do. No other CVT's I've seen has anything like them.
Unread 09-09-2006, 01:29
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
The brass fins are weights that are used to shift the cvt from a high ratio (high input to low output) to a low ratio. When the input spins fast they pull out causing the pulley they are on to close making the radius of the pulley higher this causing the ratio to get higher. When the input slows du to a larger amount of torque being need the weights are pulled in by a spring and opening the pulley making the ratio lower.
At least that is what I get from the pictures.
Unread 09-09-2006, 02:23
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
So is this an automatic CVT or do the weights simply aid in shifting?
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 09-09-2006, 03:47
Dan Richardson's Avatar
Happy Birthday! Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
CVT stands for Continuously Variable Transmission. This means that technically there is no "shifting" meaning no actual going from 1 gear to another. However the "shifting" in gear ratios happens in the variating size of the pulley.
To get an idea of what it does ( not how it works ) you can look at many off road dirt or dune buggy style cars. Also Nissan ( I believe ) has a new national advertisement of a CVT in one of their new cars. Motor revs up and no shift jerk, pretty neat.
Anyways, this is a sharp transmission I'm kinda bummed I didn't get to see this in person this year.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 09-09-2006, 09:13
ClintDog's Avatar
ClintDog ClintDog is offline
Xcats- "My Strength"
AKA: The Tank
FRC #0494 (Martians)
Team Role: Animator
ClintDog will become famous soon enough
Send a message via AIM to ClintDog
I am going to try to give you the best explanation i can. ok here we go, it is a continuously variable transmission and as the motor thats connected to it's rpm's raise the brass weight move inward towards the belt, when that happens the "gear ratio" changes making the power transfer much more efficient.
Xfire= Clintdog
Aim= Clintlight27
Unread 09-09-2006, 11:23
AdamHeard's Avatar
Lead Mentor
centrifugal force makes the weights go in?
Unread 09-09-2006, 11:56
run the trap!!!
Team Role: Human Player
Saw this in a Motor Trend article and decided to check it out.
Its quite a nifty idea and could definitely be implemented on a robot (they even mention robots as one of its applications).
Not only are they relatively small (bicycle hub) but they are also driven by chains!
-Philip J. Fry
Unread 09-09-2006, 17:02
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
INERTIA would make the weights change position, and help "shift" the gear ratio (although I've seen other CVT's, rather they use motors or other actuators to control the positioning of the pulleys).
http://auto.howstuffworks.com/cvt.html
Unread 09-09-2006, 17:54
Andrew Blair's Avatar
FRC #0306 (CRT)
Actually, to be completely accurate, it's a centripetal acceleration that causes the weights to exert a force outward, which operates the shift. Higher RPM means higher centripital acceleration, a higher force pushing outwards, and a different ratio.
More importantly, I had been ogling the available pictures of this transmission over about the past year, and when I glanced at it walking through the pits in Atlanta, myself and Cody from our team immediately ambushed the only kid in their pits. I actually apologize for that, I think I scared him a bit. "Can you demonstrate your CVT to us? Please?! We really want to see it! Please!"
Anyways, the thing is really, really cool, if it is a bit noisy. It shifts really smoothly, but it does seem to offer a lot of internal resistance to movement. But really, really slick!
-Sir Francis Bacon
-Albert Einstein
Unread 09-09-2006, 19:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Well, I was just trying to say that centrifugal force doesn't really exist
Besides, centripetal acceleration wouldn't exist without inertia. (well, little of physics would exist without other fundamental physics principles...)
Unread 10-09-2006, 01:24
Fidgetting
Thanks for the correction. However, centrifugal force does exist, it the force that keeps the citizens of a country in the country or some such like that. I learned this in my geography class 4 years ago so its a little fuzzy and I was afraid that last night a 11:30 I would get them mixed up and of course, I did.
pic: Martians at WMR Beth Sweet Extra Discussion 3 04-05-2006 15:24
Thank you Martians Jack Jones Thanks and/or Congrats 10 16-12-2005 19:59
Cvt Jack Technical Discussion 4 05-10-2002 20:59
CVT Clark Gilbert Chit-Chat 10 11-05-2002 19:38
494 Goodrich Martians - Pictures cmartin03 Robot Showcase 4 18-02-2002 23:20
